[How-To] Giving Plugins Write Permissions to Your Data
xmicks
When i changed user media to a new user with the same uid as the owner of my /Volume1/Media dataset. sabnzbd throws the warning:
"Cannot access Pid file: /var/run/sabnzbd/sabnzbd.pid"
when i had media as the user of the jail i didnt had this warning/error. Also i have problems starting and stopping sabnzbd, its quite different starting and stopping the plugin from the commandline or from the gui. for example: i stop the plugin from the commandline and when i then look in the gui. the plugin is still marked as "On".
this how ive configuered in the sabnzbd jail, (i combined option 2 and 3 of this tutorial)
pw useradd -n NewMedia -u 1002 -d /nonexistent -s /usr/sbin/nologin
pw groupmod media -m NewMedia
service sabnzbd onestop
chown -R NewMedia:media /var/db/sabnzbd
sysrc 'sabnzbd_user=NewMedia'
service sabnzbd start
later i tried giving the NewMedia user root permissions
pw usermod NewMedia -G media,wheel
Joshua Parker Ruehlig
You also need to change the owner of /var/run/sabnzbd
xmicks
didnt i do that with this command
i think it is the owner
root@sabnzbd_1:/ # ls -l /var/db/sabnzbd/
total 19
drwxr-xr-x 4 NewMedia media 4 Apr 30 21:30 Downloads
drwxr-xr-x 2 NewMedia media 8 May 1 01:43 admin
drwxr-xr-x 2 NewMedia media 4 Apr 29 19:47 logs
-rw------- 1 NewMedia media 6284 May 1 01:43 sabnzbd.ini
-rw------- 1 NewMedia media 6284 May 1 01:43 sabnzbd.ini.bak
total 19
Nope you didn't. I left out that step cause it isn't necessary for all the plugins.
xmicks
o wait i didnt read your post right:). i changed owners and i dont have the warning message. Big thanks for the help and the tutorial!!
xmicks
Do you know for which plugins its necessary?
any of them that have a pid file. check their init file in /usr/local/etc/rc.d
saintryan
I am having an issue with transmission. I have created a user called media and a group called media (816). My datasets are setup with the same user aswell.
However when i try and change the transmission jail user:group i come up against a number of issues eg:
service PLUGIN onestop
PLUGIN does not exist in /etc/rc.d or the local startup
directories (/usr/local/etc/rc.d)
The issue then is that my transmission cannot download as I do no have permission to the dataset folder.
you aren't replacing PLUGIN with the plugin name.
xmicks
now i'm configuring emby
,when i try to open this file with 'ee /usr/local/etc/rc.d' i get a empty file, and the message that that path is a directory.
i did a similar configuration as i discribed above.
but when i try to start or stop the service i get a permissions error
root@emby_2:/ # service emby-server stop
/etc/rc.conf: emby-server_user=NewMedia: not found
emby_server not running? (check /var/run/emby-server.pid).
root@emby_2:/ # service emby-server start
Starting emby_server.
daemon: pidfile ``/var/run/emby-server.pid'': Permission denied
/usr/local/etc/rc.d/emby-server: WARNING: failed to start emby_server
root@emby_2:/ #
i did a chown of /'var/run' and a chown of '/var/run/emby-server.pid' but that doenst solve the problem
note: when i did 'sysrc' i get this
root@emby_2:/ # sysrc 'emby-server_user=NewMedia'
emby-server_user: server_user -> server_user
what did i do wrong?
the init file is IN the /usr/local/etc/rc.d directory, did you read the error you posted?
the dashes should be replaced with underscores in the rc.conf
so settings for emby-server should be emby_server
xmicks
okay got it working now. the 'chown' command worked now when i used 'emby_server_user'. my previous attempts to solve this messed up the jail so i created a new jail and now everything is working.
sweet
BBarker
I have tried a few things in this excellent thread to try and get Sabnzbd to work. After install last night, it ran and I was able to configure it to work and downloaded some content just to see. This morning, the service was off and would not restart in the FreeNAS webGUI yet I could access it using my laptop using MS Edge and it is still running. I did download the latest update for FreeNAS and was able to turn the service on but when I tried to move the files it downloaded, I got a permissions error:
Here is my jails:
and this:
I know the resolution is in this thread, but I have not been able to source it out. Help please?
BBarker
I feel like I may be chasing my tail a bit here. Sabnzbd is working but I can not get the plugin to turn on?
In the webGUI for Sabnzbd it has an error message: "Cannot access PID file /var/run/sabnzbd/sabnzbd.pid"
I thought I had my ownership setup properly:
When I try to start it using the jail webGUI it shows this error:
[24/May/2016:20:38:50] HTTP
File "/usr/pbi/sabnzbd-amd64/share/sabnzbdplus/cherrypy/_cprequest.py", line 670, in respond
File "/usr/pbi/sabnzbd-amd64/share/sabnzbdplus/cherrypy/lib/encoding.py", line 217, in __call__
File "/usr/pbi/sabnzbd-amd64/share/sabnzbdplus/cherrypy/_cpdispatch.py", line 61, in __call__
File "/usr/pbi/sabnzbd-amd64/lib/python2.7/site-packages/sabnzbd/interface.py", line 741, in index
filter=FILTER, searchList=[info], compilerSettings=DIRECTIVES)
File "/usr/pbi/sabnzbd-amd64/lib/python2.7/site-packages/Cheetah/Template.py", line 1259, in __init__
File "/usr/pbi/sabnzbd-amd64/lib/python2.7/site-packages/Cheetah/Template.py", line 1546, in _compile
File "/usr/pbi/sabnzbd-amd64/lib/python2.7/genericpath.py", line 54, in getmtime
return os.stat(filename).st_mtime
OSError: [Errno 2] No such file or directory: '/usr/pbi/sabnzbd-amd64/share/sabnzbdplus/interfaces/Glitter/templates/queue.tmpl'
ERROR 24/05/2016 20:38 [24/May/2016:20:38:49] HTTP
This isn't related to permissions, but somehow your sabnzbd application files got messed up.
I suggest you do the following...
* Upload a PBI from here, like the btsync one, to your sabnzbd jail http://download.freenas.org/plugins/9/x64/
* Delete your sabnzbd plugin
* Upload the sabnzbd v1.0.2 PBI from here http://download.freenas.org/plugins/9/x64/ to your sabnzbd jail
* Delete your btsync plugin
BBarker
Interestingly enough, when I did the plugin switch as described above and then applied solution one, Sabnzbd is running and while the plugin initially turned on, after configuring Sabnzbd and restarting it for the changes to take effect, the plugin is now off and will not turn on in the FreeNAS webGUI.
I have been able to download content, it unpacks it and deletes the .rar files and I am able to move the files about and use them fine.
Can you try restarting the jail. maybe the freenas webui can make a fresh connection with the sabnzbd plugin's communication interface.
BBarker
I was thinking to leave well enough alone but I did try this with the only result being that Sabnzbd is now stopped and I can not get it to restart, no change in the webGUI...it still won't turn the plugin on:
root@sabnzbd_1:/ # service sabnzbd onestart
Starting sabnzbd.
su: pam_start: system error
/usr/local/etc/rc.d/sabnzbd: WARNING: failed to start sabnzbd
root@sabnzbd_1:/ # service sabnzbd start
Starting sabnzbd.
root@sabnzbd_1:/ #
