Niels Erik
- Aug 9, 2015
What I would like to achieve is to use existing OpenLdap server to provide authentication to my Samba server on the TrueNas Core host
I have looked at the following:
I run a number of jails with Mailserver, NextCloud, bind, OpenLdap, reverse proxy etc.
I can get PAM, SSSD, NSS, SASL to interface with LDAP inside jails without problems.
But I can't get the only service that i run outside the jails (SAMBA file server) to use LDAP(S).
I know how to use ldapsearch, and getent inside jails.
I use certificates signed by a public CA (LetsEncrypt) but the TrueNas system itself does not face the internet. (My DNS provider does not support ACME, I have made my homemade solution to move certificates from internet facing reverse proxy to internal jails)
Since both the jails and the host is a kind of FreeBSD, i would like the most to generate a /usr/local/etc/ldap.conf with the LetsEncrypt CA via. the UI.
I have looked at this:
www.ixsystems.com
Filled out Base, and Bind DN. Password, check enable.
www.ixsystems.com
Imported LetsEncrypt CA.
Nothing happens, the list of users does not get populated as with 'getent passwd' in a jail.
The normal ldap configuration files does not exist on the system, like those:
2: Let SAMBA on TrueNas Core host use MIT Kerberos server in a jail. like FreeIPA
I have tried to reverse engineer a FreeIPA docker image (MIT Kerberos, Dogtag, Bind, Apache GUI + a lot more), to recreate it in a jail.
I have not got far with this, I have a basic kerberos up and running with DNS settings, but without integration with LDAP.
The FreeIPA docker image in itself i a pain in the but... Tried to run it on WSL2, Ubuntu, Redhat, but there is a regression problem..
3: Move samba server inside a jail (in norder to be free to edit config files)
Another rabbit hole...
I kind of have zfs working in a jail... Except that i first ran into this:
www.truenas.com
Then I tried to get samba up and running then I ran into this..
I have been contemplating editing iocage to support the missing property in the config.json.
- Let SAMBA on TrueNas Core host use LDAP
- Let SAMBA on TrueNas Core host use MIT Kerberos server in a jail. like FreeIPA
- Move samba server inside a jail (in norder to be free to edit config files)
- Looking at Docker, and migration to Scale.
12. Directory Services — FreeNAS®11.3-U5 User Guide Table of Contents
7. System — FreeNAS®11.3-U5 User Guide Table of Contents
# /usr/local/etc/openldap/ldap.conf is used by LDAPSEACH
# /usr/local/etc/ldap.conf is used by PAM
# /usr/local/etc/nss_ldap.conf is used by NSS
TLS_CACERT /usr/local/etc/ssl/acme/ca-root.pem
Access .zfs snapshot from inside a jail
Hello, I have set snapshot folder visibility to yes on a data set. I then scheduled a periodic snapshot task to run on my dataset. I have then created a jail and mounted the dataset as a mount inside the jail. I then fire up the jail's ssh and navigate to the .zfs/snapshot folder and cannot...
Curiously, after I've created a new snapshot and do an ls -al /path/to/dataset/.zfs/snapshot (just ls does not help) from the base OS, I can access the new snapshot from jail.
Unfortunately iocage does not have an option to allow mount fdescfs. And according to this comment by Kris Moore, there is no plans in foreseeable future. I guess, I have to move to generic jails instead of iocage then.
