How To: change sensor thresholds with IPMI using ipmitool
STREBLO
GrumpyBear
I restarted a few times. Or do you mean try the ipmi power cycle?
Yes, restart the IPMI. You need to unplug the system to restart the IPMI by it's nature OR restart the IPMI from it's interface
STREBLO
Ok, I tried that and I also increased my thresholds at the upper level. It seems like they are switching from completely off the full blast repeatedly. If they hit the upper level does that make them turn off completely? My temperatures are fine so I'm not sure why it keeps doing this weird cycling.
STREBLO
When I output the sensor values I get this:
CPU Temp         | 30.000     | degrees C  | ok    | 0.000     | 0.000     | 0.000     | 95.000    | 100.000   | 100.000
System Temp      | 37.000     | degrees C  | ok    | -9.000    | -7.000    | -5.000    | 80.000    | 85.000    | 90.000
Peripheral Temp  | 37.000     | degrees C  | ok    | -9.000    | -7.000    | -5.000    | 80.000    | 85.000    | 90.000
PCH Temp         | 43.000     | degrees C  | ok    | -11.000   | -8.000    | -5.000    | 90.000    | 95.000    | 100.000
VRM Temp         | 33.000     | degrees C  | ok    | -9.000    | -7.000    | -5.000    | 95.000    | 100.000   | 105.000
DIMMA1 Temp      | 27.000     | degrees C  | ok    | 1.000     | 2.000     | 4.000     | 80.000    | 85.000    | 90.000
DIMMA2 Temp      | 26.000     | degrees C  | ok    | 1.000     | 2.000     | 4.000     | 80.000    | 85.000    | 90.000
DIMMB1 Temp      | 26.000     | degrees C  | ok    | 1.000     | 2.000     | 4.000     | 80.000    | 85.000    | 90.000
DIMMB2 Temp      | 25.000     | degrees C  | ok    | 1.000     | 2.000     | 4.000     | 80.000    | 85.000    | 90.000
FAN1             | 1100.000   | RPM        | ok    | 300.000   | 500.000   | 700.000   | 25300.000 | 25400.000 | 25500.000
FAN2             | 600.000    | RPM        | ok    | 300.000   | 400.000   | 500.000   | 1800.000  | 1900.000  | 2000.000
FAN3             | 600.000    | RPM        | ok    | 300.000   | 400.000   | 500.000   | 1800.000  | 1900.000  | 2000.000
FAN4             | 900.000    | RPM        | ok    | 200.000   | 300.000   | 400.000   | 1400.000  | 1500.000  | 1600.000
FANA             | 1200.000   | RPM        | ok    | 200.000   | 300.000   | 400.000   | 1400.000  | 1500.000  | 1600.000
Vcpu             | 1.818      | Volts      | ok    | 1.242     | 1.260     | 1.395     | 1.899     | 2.088     | 2.106
VDIMM            | 1.320      | Volts      | ok    | 1.096     | 1.124     | 1.201     | 1.642     | 1.719     | 1.747
12V              | 12.102     | Volts      | ok    | 10.164    | 10.521    | 10.776    | 12.918    | 13.224    | 13.224
5VCC             | 5.031      | Volts      | ok    | 4.225     | 4.380     | 4.473     | 5.372     | 5.527     | 5.589
3.3VCC           | 3.344      | Volts      | ok    | 2.804     | 2.894     | 2.969     | 3.554     | 3.659     | 3.689
VBAT             | 3.015      | Volts      | ok    | 2.400     | 2.490     | 2.595     | 3.495     | 3.600     | 3.690
AVCC             | 3.329      | Volts      | ok    | 2.399     | 2.489     | 2.594     | 3.494     | 3.599     | 3.689
VSB              | 3.254      | Volts      | ok    | 2.399     | 2.489     | 2.594     | 3.494     | 3.599     | 3.689
Chassis Intru    | 0x0        | discrete   | 0x0000| na        | na        | na        | na        | na        | na
Are my lower thresholds possibly too high? My fans are:
FAN4, FANA: Noctua NF-P14s redux-1200
Max Speed: 1200 RPM (+-10%)
Min Speed: 400 RPM (+-20%)
FAN2, FAN3: ENERMAX T.B. Silence UCTB12P
Max Speed: 1500 (+/- 10%) RPM
Min Speed: 500 (+/- 10%) RPM
Bidule0hm
Server Electronics Sorcerer
It's the lower thresholds, set them lower (like 100, 200, 300 for example) ;)
The fans run to slow so the MB believe they are stalled so it goes in stall recovery mode (full power to the fan) so the fan speed up, the MB clear the stall error, etc...
STREBLO
I'll try that, I was afraid to go too low.
STREBLO
So that got them running constantly, there are no longer cycling . However my fans are now running at full blast, is there any way to actually make them change based on the CPU temperature? I thought that's what pwn was supposed to do .
CPU Temp         | 28.000     | degrees C  | ok    | 0.000     | 0.000     | 0.000     | 95.000    | 100.000   | 100.000
System Temp      | 32.000     | degrees C  | ok    | -9.000    | -7.000    | -5.000    | 80.000    | 85.000    | 90.000
Peripheral Temp  | 34.000     | degrees C  | ok    | -9.000    | -7.000    | -5.000    | 80.000    | 85.000    | 90.000
PCH Temp         | 39.000     | degrees C  | ok    | -11.000   | -8.000    | -5.000    | 90.000    | 95.000    | 100.000
VRM Temp         | 30.000     | degrees C  | ok    | -9.000    | -7.000    | -5.000    | 95.000    | 100.000   | 105.000
DIMMA1 Temp      | 24.000     | degrees C  | ok    | 1.000     | 2.000     | 4.000     | 80.000    | 85.000    | 90.000
DIMMA2 Temp      | 24.000     | degrees C  | ok    | 1.000     | 2.000     | 4.000     | 80.000    | 85.000    | 90.000
DIMMB1 Temp      | 24.000     | degrees C  | ok    | 1.000     | 2.000     | 4.000     | 80.000    | 85.000    | 90.000
DIMMB2 Temp      | 23.000     | degrees C  | ok    | 1.000     | 2.000     | 4.000     | 80.000    | 85.000    | 90.000
FAN1             | 2000.000   | RPM        | ok    | 300.000   | 500.000   | 700.000   | 25300.000 | 25400.000 | 25500.000
FAN2             | 1600.000   | RPM        | nc    | 100.000   | 200.000   | 300.000   | 1600.000  | 1700.000  | 1800.000
FAN3             | 1600.000   | RPM        | nc    | 100.000   | 200.000   | 300.000   | 1600.000  | 1700.000  | 1800.000
FAN4             | 1200.000   | RPM        | ok    | 100.000   | 200.000   | 300.000   | 1300.000  | 1400.000  | 1500.000
FANA             | 1200.000   | RPM        | ok    | 100.000   | 200.000   | 300.000   | 1300.000  | 1400.000  | 1500.000
VSB              | 3.269      | Volts      | ok    | 2.399     | 2.489     | 2.594     | 3.494     | 3.599     | 3.689
STREBLO
Mybad, just needed to cycle again. Thanks, working now.
Bidule0hm
No problem ;)
FYI there's a few cooling profiles (normal, full speed, quiet, ...), you can chose the one you want in the IPMI interface.
STREBLO
No problem ;)
Really. Thanks i'll take a look.
Edit:
The only thing I could find was "Fan Mode Settings", is that what you meant?
i.e.
Current FAN Mode is Optimal.
Set Fan to Standard Speed
Set Fan to Full Speed
Set Fan to Optimal Speed
Set Fan to HeavyIO Speed
Bidule0hm
Yep, that's it (I said it from memory so...) ;)
Z300M
Strange: I found that the only way I could stop my fan speeds cycling was to set the lower limits no lower than 400rpm.
naq90
When I type into the console: kldload ipmi.ko
I get back: kldload: an error occurred while loading the module. Please check dmesg(8) for more details.
Could someone help me out with this error?
Bidule0hm
The module is already loaded, just go to the next command ;)
naq90
Thanks for the quick reply. When I try the next command, ipmitool sensor list all
I get back: Could not open device at /dev/ipmi0 or /dev/ipmi/0 or /dev/ipmidev/0: No such file or directory
Bidule0hm
Mhh, sorry, I have no idea for this one.
What's your hardware'
naq90
I've got a Supermicro X10SL7‑F with an Intel E3-1246V3 and 4x8 GB Crucial ECC Ram
10 x 4TB HGST Deskstar Nas HDDs, 2 x 250GB Sasmsung 850, 1 x 100GB Intel DC S3700 SSD
Can you access IPMI through the web interface? Does a different IPMI utility work?
naq90
Yes, I can access it through the web interface but there I only have four settings; Standard, Full IO, Full, Optimal. I'm not familiar with any other IPMI utilities. What would you suggest?
