How to auto-expand items in Devices menu TrueNAS SCALE?
Sawtaytoes
I'm on TrueNAS SCALE, and unlike TrueNAS Core, some functionality seems to be missing in the new UI.
How do I have all arrays auto-expand when opening the Devices panel?
What I see now:
What I want to see:
Yes, I can open these up by hand, but I have 14 mirros in this one zpool. The issue is I'm testing certain drives for errors, but I can't easily for errors when everything's collapsed.
This is an example where the mirror is fine, but a single drive has an issue:
If it was closed, I would see "No Errors".
artlessknave
to my knowledge, you don't, you would likely find this easier with zpool status -v
Sawtaytoes
That's what I've been doing, but I'd prefer to never use the CLI when using TrueNAS.
I can't do it from my phone (which is what I use when I'm working on my NAS), and it used to expand by default in TrueNAS Core.
artlessknave
"UpGrAdEs"
Go to the pools list, click (or tap if you're on the phone) the cogwheel on the right of your pool, select Status from that list.
EDIT: OK, I see that is for CORE and you're asking about SCALE (which has changed that view in Bluefin to make it rather bad for mobile).
No can do is the current answer for SCALE.
