How to access nextcloud running on truenas scale from internet
kashifqazi
I have installed TrueNas Scale and installed nextcloud running on port 9001
I have purchased a dns and setup a reord
I have setup port forwarding 80 and 443 to my truenas scale machine.
when accessing it from internet it is sending me to true nas scale login page not on the nextcloud running on port 9001
how to fix this so when i access from internet it goes to my next cloud not the truenas scale?
can anyone help please thanks.
Maybe forward those ports to 9001 rather than to 80/443?
kashifqazi
I setup the port forwarding but still not able to access nextcloud on true nas scale.
can you please help what is the problems
Samuel Tai
You didn't actually create a passthrough to your NextCloud; you created an open port 9001 to your router. Delete those NAT entries and try setting it up under IP Passthrough.
kashifqazi
Setup the IP pass through but it is also no working.
I'm only able to acces truenas through internet when i add port forwarding.
Not able to acess nextcloud through internet.
can you please help what is the issue.
ChrisRJ
What is your use-case? Are you aware of the security implications?
duderuud
phradr
Have you tried to edit the nextcloud config?
We discussed a similar effect on nextcloud docker. I gave a description here (LINK). Maybe it helps.
