How should I deal with this failure?
BottomsUp
This is a 2 disk mirror. the disks are pretty old so I guess I should offload all of the data, re-built from scratch with 2 new disks and load the data back?
You can check the smart status or run a long self test, but those errors are an indication of impending doom. In fact some data may already be corrupted since there are errors on both drives. Backup your config and data ASAP.
FYI, FreeNAS is now TrueNAS. When you build a new system, install TrueNAS instead. Also, there were alerts in January and mid May. When you set up the new system, its highly recommended you set up email notifications on alerts so you can take immediate action to prevent data loss.
smartctl -a /dev/ada0
smartctl -a /dev/ada1
smartctl -t long /dev/ada0
smartctl -t long /dev/ada1
I guess you could. But if it were I, I'd replace the one disk, then the other. No need to move data off-pool and then back on.
Which one first? Maybe the one already booted from the array?
Samuel Tai
ada0 first, as that seems to be further along the path to death.
Etorix
If you have enough spare ports, just plug the new drives and replace both drives in one go!
