How do you install truenas on dell power edge 2970
Brian45
When I go to the installation menu it says no drive are there but there are 4 500gb drive installed on the server
Samuel Tai
Wipe all the drives. TrueNAS refuses to install on drives with existing partitions as a safety measure.
Samuel Tai
What drive controller do you have in your Dell?
Samuel Tai
Yes, unfortunately, you have the wrong controller for TrueNAS. This is a RAID controller, not an HBA.
You'll need to replace it with an H200 or H310.
Samuel Tai
You’re misinformed. Search this forum for many folks with good experiences with the H200.
Samuel Tai
Order it with the correct cables. Then replace the cable runs to the backplane.
