of COURSE i looked through the documentation, but TNC refuses to behave...
i went Pools-> clicked the gear ->status, clicked the 3 ... next to the failed drive, offlined it, inserted the new drive (after verifying it was completely blank), clicked replace, chose the drive from the memberdisk dropdown (with Force checked), and...
what gives? this shouldn't be this difficult
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 355, in run
await self.future
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 391, in __run_body
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 981, in nf
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool_/replace_disk.py", line 78, in replace
await self.middleware.call('pool.format_disks', job, disks)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1283, in call
return await self._call(
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1240, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool_/format_disks.py", line 28, in format_disks
await asyncio_map(format_disk, disks.items(), limit=16)
File "/usr/local/lib/python3.9/site-packages/middlewared/utils/asyncio_.py", line 16, in asyncio_map
return await asyncio.gather(*futures)
File "/usr/local/lib/python3.9/site-packages/middlewared/utils/asyncio_.py", line 13, in func
return await real_func(arg)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool_/format_disks.py", line 24, in format_disk
await self.middleware.call('disk.format', disk, swapgb if config['create_swap'] else 0, False)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1251, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1156, in run_in_executor
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/disk_/format.py", line 21, in format
raise CallError(f'Failed to wipe disk {disk}: {job.error}')
middlewared.service_exception.CallError: [EFAULT] Failed to wipe disk da4: [Errno 6] Device not configured
