How Do I Enable Encryption And How Do I Start A S.M.A.R.T Test On My Drives?
ArcticWolf_11
Hello, new to FreeNAS and I checked the option when creating my volume to enable encryption is that all I needed to do and can I change what type of encryption that it uses? I have also made a job to automatically do S.M.A.R.T tests but I can't figure out how to do one at will. One last thing, I have my compression set to Gzip-9. If I find that it is too slow, can I select another compression method without any consequences such as having to re-upload all my files back to the box or will it convert it automatically? Thanks! :D
Yes. But download your backup key or you'll lose your data some day.
No.
From the command line. smartctl -t (long|short) (device)
Why?
Yes, but the data currently compressed as gz9 will stay that way--only newly-written data will be compressed with the new method.
I count three completely unrelated questions here. It probably would be better to start separate threads for unrelated questions (after searching for the answers, of course).
ArcticWolf_11
No.
Why?
Thanks and sorry about that, just didn't want to split this into multiple threads as I thought these were simple questions but for some reason I couldn't find it in google. The reason why I chose Gzip-9 is because I wanted to save the most space possible for my files so that I won't have to worry about getting larger drives for a long time. I understand that it is really taxing on the CPU but the server that I have has 2x E5-2450L @ 1.8Ghz base so I assume it should be enough (enough to saturate gigabit/my hard drive's read and write speeds hopefully).
Chris Moore
Most data for home use, like video and audio files, isn't very compressible.
ArcticWolf_11
Yeah I know but around 90% of my data are files that aren't videos so i'd benefit from it. I store most of my video files to another folder to which I can just disable compression.
MrToddsFriends
Documentation Browser
Please write dataset if you mean dataset to avoid confusion. The compression setting in ZFS is specific to datasets.
