BlackRockCity
- Nov 22, 2020
As per the link below, I ran the following command on 4 newly installed hard drives to accomplish some burn-in testing:
badblocks -ws /dev/adaX
Then I got broken pipes on my terminal because I switched WiFi networks (something I do often).
Is there a way to check the status or results of the badblocks command now that the command is no longer associated with a terminal session? It takes so long to run that I don't want to have to repeat it.
www.truenas.com
Hard Drive Burn-in Testing
@jgreco did a nice system build/test/burn-in guide here, but I (and many others) found the details a bit lacking in the hard drive section. He mentions S.M.A.R.T. tests, but doesn't go over how to run them, or how to view the results, etc. and...
