Homeassistant update problem
MrJoki007
im using homeassistant as an plugin on my truenas scale server.
Im having the problem, when i try to upgrade from my current homeassistant version 2022.12.8_18.0.23 to a newer one, it gets stuck at DEPLOYING 1/2 .
When i roll back to the old version, it works again. I've tried all newer versions, that i can select, but everywhere theres the same problem.
Pod logs are completly empty.
mudbuddha69
having the same issue
FJep
Sorry I can't with your problem, but I reccomend the use of HAOS in a VM.
Prior to using this approach I went with jails like you. One for Homeassistant and one for MQTT and so on.
It was very much work to keep them uptodate.
When I wanted to use Nod-Red and Graphana I came across HAOS.
I made a backup of my config and setup a VM and installed HAOS to it.
There you can install MQTT, Node-Red, Graphana from the webinterface as addin and all updates are simple mouse clicks.
Today I get 2-4 updates each month and I am uptodate without much effort.
