Hello.
Is there a way to change the way that Truenas names the Home Share folders, to have them be username@domain.tld ?
What I'm trying to do:
Using FQDN user accounts:
I have tried to login with the FQDN to create the folders, and then switch to the non-FQDN version to make of the good path name, but it won't authenticate successfully to mount the share with: mount error(13): Permission denied
Is there a way to change the way that Truenas names the Home Share folders, for Active Directory users, to have them be username@domain.tld instead of DOMAIN/username ?
Many thanks!
I have enrolled my Truenas into my AD (which is running in Nethserver).
I am using Ubuntu 22.04
I am trying to mount this folder as the ubuntu workstations /home/%(USER) directory via pam_mount
pam_mkhomdir is not creating the folders on the share, so I set an SMB share with "Use as Home Share" and am trying to leverage this functionality.
- I log into the FQDN for the user: testUser@company.com
- The user is authenticated successfully.
- Truenas will create the Home Share folder, under /mnt/myPool/myDataset/COMPANY/testUser but it strips anything after and including the @.
- The mount will fail because In pam_mount I have no way to strip the @company.com portion of the mount path, so Linux will try to mount:
- /mnt/myPool/myDataset/COMPANY/testUser@company.com
- When this is the folder that is actually available:
- I change sssd.conf to use local names: testUser
- Truenas does not create the Home Share folder, with the error: mount error(13): Permission denied
Many thanks!
