Warning: Long Post xD
If you do not care about specs and other info and thoughts, I would appreciate help with HDD section
CPU: AMD R7 5800X3D
MoBo: Gigabyte B550 Aorus Elite V2
RAM: 2x16GB UDIMM ECC - Samsung 3200MHz
BootDrive: 2x 240GB Kingston A400
HBA: AOC-S2308L-L8i - In IT mode.
HDD Old: 3x WD Red 8TB (Plus - bought before they even became Plus series) + 1x WD Red Pro 8TB
HDD New: 4x WD Red Plus 8TB
Pool: 8 Drives in RaidZ2
SLOG: 2x Intel Optane 16GB modules
OS: TrueNAS Scale
A few notes for the specs:
CPU: I get that it is kinda overkill for just a "simple" HDD array. I plan to maybe put some more Dockers. I'll also try Plex and use it to offload transcoding x264 and x265 to the server itself (as I like ridiculous mega placebo params xD)
MoBo: I tested and in theory, the board is working correctly with ECC. It is not perfect as the normal platform lacks the necessary modules to properly check ECC RAM - No Error injection or even proper reposting of Error corrections but all hardware and software pointers say that ECC is ok.
RAM: So 32GB now with the possibility to upgrade to 64GB if I see the need.
BootDrive: 120GB should be enough but 240 costed literally 2$ more in the shop so I just went with them.
HBA: Afaik it should be good :P It will be slotted into the x16 slot first but might be moved into the x2 slot later. I know the bandwidth is not the best with it, but even with PCIe 3.0 x1, the 2.5GbE would not be fully saturated with it so I think it will be fine.
SLOG: I want to use "Sync: Always" on a few datasets and I might host a few VMs in which case it will help. In theory, the 170-180MB/s writes they give will not be enough to saturate the 2.5GbE that the MoBo has but I do not worry about it as not all traffic will get there, and even if it did, it is still like 1.5Gb which I would be more than happy with. I was thinking about getting a single (2 would be too much $$$ for that for me) P4800x/P4801x like 100GB model for that and maybe even for mini L2ARC later but might not be even necessary if I ever upgrade the RAM to 64GB.
HDD: This is a huge problem and I'm not 100% sure what to do about it. I read about it some but I would still like to get some insight into it.
Right now I have "HDD Old" set so 3 drives at 5400 (or more, WD is kinda weird about the actual speed on those) and 1 drive at 7200. I have 2 options:
1. Buy 4 WD Red (5400 RPM) and have 7 5400 and 1 7200
2. Buy 5 WD Red and have all the "same" 5400 RPM drives. This however means ill have 1 random free 8 TB drive that I'll have nothing to do with.
Is option 1 a bad idea? From what I heard, mixing different RPM drives is not really that bad and should not really affect anything. In reality, everything should just be as fast as the 5400 RPM so I do not really lose anything. Option 2 is in theory possible but would cost me more and leave me with 1 random drive which is kinda wasteful imo.
OS: I went with Scale even tho there are a few vids and posts I saw with lower performance compared to Core which should not impact me a lot. It will allow me to use Dockers which I'm muuuch more familiar with, which I hope will help me with the whole setup and everything.
Notes about usage:
The system will 95% be used for rather "cold" data to store mostly backup/archive data and some media for potential Plex - movies, series, and anime. The server might have a few Dockers for some services like Plex, Cloud, Media Conversion (x264/x265), and maybe some more, we will see. It will be mostly used by 1/2 people as it is a data storage for home usage.
This should give me some possible expansion in terms of RAM (32 -> 64) and possible SLOG (and) L2ARC upgrade possible P4800X that might even be used also as L2ARC but I think it should not be necessary due to the usage being mostly Archival (no real need for huge cache/L2ARC) and mostly working with larger media files.
I think that I thought about the whole setup as good enough for my usage but I still need some insight if Option 1 in the HDD section is ok. Do you think I went super off in some aspect of the build or it should be ok? I really wanted to do as many things as "right" as possible so I really wanted ECC RAM, I cut corners a little bit with HDDs as they are SATA but the HBA is SAS, not sure if it is something to be "proud" about but I thought having proper HBA with SATA drives is better than just SATA controller with SATA drives, maybe I'm super wrong about it tho xD
CPU: AMD R7 5800X3D
OS: TrueNAS Scale
Notes about usage:
