Home Assistant in TrueNAS-SCALE-23.10.1 /Truenas Mini R
svgtruenas
I have venture into the NAS world and I am trying to install true-charts homeassistant but I am having a difficult find a good installation source,most are outdated.I am hoping that someone can point me in the right direction.I am very new to truenas scale and the true-charts installation.I have installed true-charts just looking for direction with the homeassistant installation.
Thanks
kaushik
I am in the same boat. I am using TerraMaster f4-423. Any assistance on the installation of Homeassistant with scale version 23.10.2. Thanks
kaushik
would be greatly appreciated.
chuck32
Not an answer to the explicit question but I'd install as a VM. If I'm not mistaken the app version is already a container and this you will not be able to addons directly.
Have a look here:
I'm running the same installation with no problems for a year now.
kaushik
Have a look here:
Thanks for the response. I'll give it a go and report back.
kaushik
I followed the steps outlined and when I start the VM and launch the display, I get via Spice an UEFI Interactive Shell.
As I mentioned above I am new to Truenas/Linux and would be grateful for any pointers/assistance on the next steps to get Homeassistant running. Thanks.
chuck32
Can you show your VM settings? I assume you correctly created the zvol and attached it as a disk to the VM?
Can you exit and then boot?
tprelog
This usually happens if we use the incorrect path when writing the HAOS image to our zvol.
Notice in the following command that the path starts with /dev/zvol
qemu-img convert -O raw haos_ova-12.1.qcow2 /dev/zvol/tank/vm/haos
If you’re still having trouble, please share the exact command you used for this step.
kaushik
Thanks guys for your responses.
In my installation, I used the following commands for HAOS:
unxz haos_ova-12.1.qcow2.xz​
qemu-img convert -O raw haos_ova-12.1.qcow2 /mnt/system/VirtualMachine/haos​
And, the HAOS has been created in the correct location.
The details of the VM are:
Details of the Zvol are as follows:
I still get the:
I am doing something stupid, but I just can't see it!
Hopefully, the above details will help to highlight what I am doing wrong.
Thanks.
tprelog
It looks like you are using the wrong path to your zvol. Notice the path you used starts with /mnt
However, the path should start with /dev/zvol - So, the correct command for you should be:
qemu-img convert -O raw haos_ova-12.1.qcow2 /dev/zvol/system/VirtualMachine/haos
Otherwise, everything else looks correct!
kaushik
You are a star! I made the change and now I get:
My bad, I didn't read your first response correctly.
Anyways, the next step is to get the Homeassisstant GUI up and running. Could please point me in the right direction for this?
Thanks.
tprelog
chuck32
Thank you, this worked :smile:
Can you please let me know where this is documented for future reference?
It says so on your spice output ;)
But the port 8123 is always the same and HA reports its IP.
tprelog
Yep, precisely what Chuck said.
As far as documentation - it's mentioned in the onboarding section of getting started
kaushik
Sorry for being such a newbie guys. I appreciate your assistance and hopefully, I'll get better with practice.
