Home Assistant application not starting on SCALE
varma01
I can't seem to get the new Home Assistant application to work on TrueNAS Scale, if it has the Host network option enabled.
I have tried:
- Updating to the latest version of SCALE,
- Re-making the application,
- Adding DNS servers to the application config,
- Refreshing the application catalog,
- Reinstalling TrueNAS
Non of the above have fixed the issue, it always just says Deploying 1/2.
2022-06-08 13:54:05
Nameserver limits were exceeded, some nameservers have been omitted, the applied nameserver line is: 8.8.4.4 1.0.0.1 8.8.8.8
2022-06-08 13:54:05
2022-06-08 13:54:07
Started container init-postgresdb
2022-06-08 13:54:07
Started container home-assistant-postgres
2022-06-08 13:54:07
Created container init-postgresdb
2022-06-08 13:54:07
Created container home-assistant-postgres
2022-06-08 13:54:06
Container image "postgres:13.1" already present on machine
2022-06-08 13:54:06
Successfully assigned ix-hass-instance/hass-instance-home-assistant-7ff5685587-jhjd7 to ix-truenas
2022-06-08 13:54:05
Created pod: hass-instance-home-assistant-7ff5685587-jhjd7
Successfully assigned ix-hass-instance/hass-instance-home-assistant-postgres-86c496c6b8-rm8tc to ix-truenas
2022-06-08 13:54:05
Created pod: hass-instance-home-assistant-postgres-86c496c6b8-rm8tc
2022-06-08 13:54:05
Scaled up replica set hass-instance-home-assistant-7ff5685587 to 1
2022-06-08 13:54:05
Scaled up replica set hass-instance-home-assistant-postgres-86c496c6b8 to 1
2022-06-08 13:54:05
MountVolume.SetUp failed for volume "kube-api-access-hgwjf" : object "ix-hass-instance"/"kube-root-ca.crt" not registered
2022-06-08 13:54:05
Job completed
2022-06-08 13:54:05
Started container pre-install-job
2022-06-08 13:54:04
Created container pre-install-job
2022-06-08 13:54:04
Successfully pulled image "alpine:latest" in 1.661964539s
2022-06-08 13:54:02
Pulling image "alpine:latest"
2022-06-08 13:54:02
Add eth0 [172.16.0.59/16] from ix-net
Successfully assigned ix-hass-instance/hass-instance-home-assistant-preinstall-job-ngrzw to ix-truenas
2022-06-08 13:54:01
Created pod: hass-instance-home-assistant-preinstall-job-ngrzw
TrueNAS system debug info: in attachments
  • debug-truenas-20220608142003.tgz
Do you really need to set the advanced DNS settings?
Seems HA is throwing an error about too many DNS.
varma01
I reduced it down to two DNS servers, but it still doesn't work... The DNS errors are gone tho.
2022-06-08 16:20:24
2022-06-08 16:20:24
2022-06-08 16:20:24
2022-06-08 16:20:24
2022-06-08 16:20:24
2022-06-08 16:20:24
Successfully assigned ix-hass/hass-home-assistant-postgres-7b8df5569b-54sst to ix-truenas
2022-06-08 16:20:23
Scaled up replica set hass-home-assistant-postgres-7b8df5569b to 1
2022-06-08 16:20:23
Created pod: hass-home-assistant-postgres-7b8df5569b-54sst
Successfully assigned ix-hass/hass-home-assistant-75b9bfd76f-n9vtq to ix-truenas
2022-06-08 16:20:23
Created pod: hass-home-assistant-75b9bfd76f-n9vtq
2022-06-08 16:20:23
Scaled up replica set hass-home-assistant-75b9bfd76f to 1
2022-06-08 16:20:23
MountVolume.SetUp failed for volume "kube-api-access-5rshh" : object "ix-hass"/"kube-root-ca.crt" not registered
2022-06-08 16:20:23
Job completed
2022-06-08 16:20:23
2022-06-08 16:20:23
2022-06-08 16:20:22
Successfully pulled image "alpine:latest" in 1.722192344s
2022-06-08 16:20:21
2022-06-08 16:20:21
Add eth0 [172.16.0.65/16] from ix-net
Successfully assigned ix-hass/hass-home-assistant-preinstall-job-lzfst to ix-truenas
2022-06-08 16:20:20
Created pod: hass-home-assistant-preinstall-job-lzfst
pixelwave
...same issue here. Trying the official Home Assistant app from TrueNAS Scale Charts but it is not launching when "HOST NETWORK" is checked.
I am trying to get WOL from Home Assistant working. So far with my Docker HA install I was not able to send a magic packet from HA to start another computer remotely.
sixdas
Hi, has anyone managed to fix this? also i am trying but i cant boot if i turn on Host Network
pixelwave
I am running the Docker-Hub version - not the TrueCharts one.
I have "privileged mode" enabled:
And in the ha-config:
# Custom Switches
switch:
# WOL - Workstation
- platform: wake_on_lan
mac: "04-***"
host: 192.*** #ip of target machine
broadcast_address: 192.*** #ip of target machine
broadcast_port: 9
turn_off:
service: script.workstation_shutdown
The weird behaviour is .. I am able to remotely WOL the machine but only when it was on recently (like the last few minutes).
After a couple of hours it does not wake up. When I send the WOL package from my Mac miniWOL app it works every time though...
