Help with zfs drives
louiecola2
Hello I have freenas 9.1.1 and have two drives that are mirrored ( raid1 ) and just added a third drive to the freenas. When i went into view disk and volumes it seems like the zfs took control of the third drive because it says 382 gigs rather then 226 gigs which is what it said before. Also it doesn't say which drive is which just by sn# . I want to setup the third drive for other store separate from the two drives.
FreeNAS doesn't just "take control of the third drive". You had to add the disk to a pool or something. So the real question is what did you do to create whatever configuration you are currently in.
Post the output of zpool status in CODE tags.
