azjet77
- Nov 20, 2023
Disclaimer: it's my first time running TrueNAS and ZFS, by extension. I recently put together a new NAS machine, the specs are:
I collected some data using gstat during the slower writes:
I also did a test using
Is this to be expected with this configuration or is something else going on?
- Chassis/MB
- Supermicro CSE-836e16/X11SSH-GF-1585L
- CPU
- Xeon E3-1585L v5
- RAM
- 64GB ECC DDR4 2133MHz
- Storage
- TrueNAS Core on Crucial MX500
- Pool = 4x 16TB 7.2k Seagate Exos X18 ST16000NM000J in RAIDZ1
- Hard disk controllers
- Inspur LSI SAS-3008 controller (in IT mode)
- Network cards
- Onboard 1Gbe LAN
archives dataset under it using compression=lz4, dedup=off, recordsize=512k. Then I ran rsync from my old NAS to transfer data to this one using rsync -rP -e 'ssh -c aes128-cbc -o compression=no'. Initially, the transfer speed (as reported by rsync) was 105-110MB/s, which is to be expected if it's filling up ZFS cache first and encountering no network issues. But some time later, I assume after the cache filled up, the speed dropped to 35-40MB/s and then slowly crept up to around 60-65MB/s.I collected some data using gstat during the slower writes:
truenas% gstat -s -b -f '^da'
dT: 1.041s w: 1.000s filter: ^da
L(q) ops/s r/s kB kBps ms/r w/s kB kBps ms/w %busy Name
0 271 0 0 0 0.0 271 665 180120 1.9 52.3 da0
1 209 0 0 0 0.0 209 832 174281 3.7 78.1 da1
0 274 0 0 0 0.0 274 658 180120 1.9 52.4 da2
1 212 0 0 0 0.0 212 822 174400 3.7 78.0 da3
0 0 0 0 0 0.0 0 0 0 0.0 0.0 da3p1
0 0 0 0 0 0.0 0 0 0 0.0 0.0 da2p1
0 0 0 0 0 0.0 0 0 0 0.0 0.0 da1p1
0 0 0 0 0 0.0 0 0 0 0.0 0.0 da0p1
1 212 0 0 0 0.0 212 822 174400 3.7 78.0 da3p2
1 209 0 0 0 0.0 209 832 174281 3.7 78.1 da1p2
0 271 0 0 0 0.0 271 665 180120 1.9 52.4 da0p2
0 274 0 0 0 0.0 274 658 180120 1.9 52.4 da2p2
dT: 1.001s w: 1.000s filter: ^da
1 130 0 0 0 0.0 130 823 106927 3.2 41.0 da0
1 118 0 0 0 0.0 118 854 100716 3.5 40.9 da1
1 137 0 0 0 0.0 137 800 109505 3.0 41.0 da2
1 127 0 0 0 0.0 127 830 105376 3.2 41.1 da3
1 127 0 0 0 0.0 127 830 105376 3.2 41.1 da3p2
1 118 0 0 0 0.0 118 854 100716 3.5 40.9 da1p2
1 130 0 0 0 0.0 130 823 106927 3.2 41.0 da0p2
1 137 0 0 0 0.0 137 800 109505 3.0 41.0 da2p2I also did a test using
fio:Code:
truenas% fio --name=test --size=5g --rw=write --ioengine=posixaio --direct=1 --bs=512k
test: (g=0): rw=write, bs=(R) 512KiB-512KiB, (W) 512KiB-512KiB, (T) 512KiB-512KiB, ioengine=posixaio, iodepth=1
fio-3.28
Starting 1 process
test: Laying out IO file (1 file / 5120MiB)
Jobs: 1 (f=1): [W(1)][-.-%][w=822MiB/s][w=1643 IOPS][eta 00m:00s]
test: (groupid=0, jobs=1): err= 0: pid=33083: Fri Jan 26 09:18:07 2024
write: IOPS=2933, BW=1467MiB/s (1538MB/s)(5120MiB/3491msec); 0 zone resets
slat (usec): min=4, max=3745, avg=32.08, stdev=61.01
clat (nsec): min=900, max=2169.1k, avg=307591.28, stdev=336626.21
lat (usec): min=31, max=3971, avg=339.67, stdev=331.07
clat percentiles (nsec):
| 1.00th=[ 988], 5.00th=[ 1020], 10.00th=[ 1048],
| 20.00th=[ 27008], 30.00th=[ 34560], 40.00th=[ 109056],
| 50.00th=[ 154624], 60.00th=[ 284672], 70.00th=[ 544768],
| 80.00th=[ 602112], 90.00th=[ 651264], 95.00th=[1155072],
| 99.00th=[1253376], 99.50th=[1269760], 99.90th=[1499136],
| 99.95th=[1531904], 99.99th=[2007040]
bw ( MiB/s): min= 813, max= 5019, per=100.00%, avg=1573.03, stdev=1689.42, samples=6
iops : min= 1626, max=10039, avg=3145.83, stdev=3378.65, samples=6
lat (nsec) : 1000=1.91%
lat (usec) : 2=16.64%, 4=0.49%, 10=0.08%, 20=0.23%, 50=19.09%
lat (usec) : 100=1.37%, 250=18.82%, 500=7.02%, 750=27.46%, 1000=1.40%
lat (msec) : 2=5.47%, 4=0.02%
cpu : usr=4.53%, sys=1.78%, ctx=10607, majf=1, minf=1
IO depths : 1=100.0%, 2=0.0%, 4=0.0%, 8=0.0%, 16=0.0%, 32=0.0%, >=64=0.0%
submit : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
complete : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
issued rwts: total=0,10240,0,0 short=0,0,0,0 dropped=0,0,0,0
latency : target=0, window=0, percentile=100.00%, depth=1
Run status group 0 (all jobs):
WRITE: bw=1467MiB/s (1538MB/s), 1467MiB/s-1467MiB/s (1538MB/s-1538MB/s), io=5120MiB (5369MB), run=3491-3491msecIs this to be expected with this configuration or is something else going on?
