Help with storage size - critical, actually is not
netaccs
I have freenas 9.10.2
4 WD 3TB HDD with zfs.
Error appear in home screen:
The capacity for the volume 'storage' is currently at 92%, while the recommended value is below 80%.
I used this storage only to make copy of virtual machines, presented via iscsi on vmware
The actual size of used content is ~ 3301 GB. I calculate the size of virtual machines backups.
Where this space is gone, how can access other ~ 4TB of space ?
#zfs list
Thanks in advance !
snaptec
Under Storage -> snapshot tasks or have a look unter Storage -> snapshots if there are any...
netaccs
The problem was that the iscsi does not free deleted files or something similar.
I use this guide to "fix" the space. Now free I have more free space, almost 3TB, according vmware I should have 4.5 TB.
