Help with R720 - Dell 12Gbs HBA - 3PAR - setup
Zed1930
I'm back to playing with TrueNAS and got an idea in my mind and bought some gear on ebay to try to build a little pet SAN. The end goal is to serve esxi VMs off of iscsi in my little home lab.
That being said, I had an old Dell R720 lying around, bough some new RAM/SSD/CPU/disks etc. I bought a Dell 0t93gd 12 Gigabit SAS HBA card, and a 3PAR StorServ 8000 enclosure, and I installed the latest version of TrueNAS onto a USB key (just to get my proof of concept and get all the gear recognized/talking to each other before actually installing, setting up a SLOG etc). I did research in the forums before buying everything and got the feeling that what I wanted to do was possible. I think TrueNAS sees the Dell HBA (9300e) card and the enclosure, but when I put two random SATA drives into the 3PAR I don't see any disks show up (on the web gui, or cli commands for what it's worth).
Running version 13.1:
My HBA card (Product ID says IT?):
The enclosure is seen as Xyratex?
gpart list only shows usb and one internal disk.
The HBA again:
Again only a USB key:
I think that the card is already in HBA/IT mode? I've been reviewing the process to "flash it back" to a stock LSI IT mode (from a ServeTheHome thread), however one of the first commands (FreeDOS) "megacli -adpallinfo -a0" was only showing the H710 mini in the system, so I pulled it out figuring maybe the command was getting confused :grin:. However rerunning it just shows "ERROR: Could not detect controller".
I feel like I'm either missing something really simple (I turned on only one of the Enclosure PSUs, or maybe got the SFF-8644 cabling wrong?), the DELL HBA proprietary firmware is not liking the HP enclosure or taking for granted that it's actually a Dell enclosure while it's not, or I'm completely wrong in my idea of being able to connect an external enclosure to TrueNAS.
Any ideas?
My next steps were:
  • Try flashing the card away from Dell proprietary, but want to make sure to measure two or three times before cutting :smile:
  • Try reading the 3PAR 8000 manual to see if there are any gotcha's I'm missing like position of the screws for SATA or ...
Zed1930
So going down the rabbithole of 3PAR documentation I noticed that the LED status of the disks was amber, indicating "defective" disk. I went to find an old SAS disk and now I get a green LED status on that tray, but still don't see it in TrueNAS, even after a "camcontrol rescan all"
So:
  • Either the 3PAR (or it's last config?) doesn't like SATA
  • Or the 3PAR doesn't like 512 disks
  • Or the enclosure controller is acting as a sort of "raid" controller and obfuscating something from TrueNAS's perspective so it can't read the individual disks?
going to keep troubleshooting...
Zed1930
Ok I found the command "getencstat -v /dev/ses1" from https://people.freebsd.org/~mav/Enclosure_Management_en.pdf
ses1 is the device name I see when I turn on the 3PAR.
So I can see the 3 disks I have plugged in right now!
I wonder if the 3PAR controllers remember a previous config as one of the SATAs is Critical, while the other is swapped? Or Maybe it's cause I tried re-seating the second SATA drive.
And I wonder if it's a driver issue finally because some of the "SAS" stuff on the enclosure is unsupported or not installed. Or maybe it's because I only have one SFF-8644 connected now to eliminate sources of problems and simplify the setup.
