malibumike
- Nov 4, 2012
Hi folks,
While i'm sort of on the fence about building a freenas, I have seen that it is fairly affordable, especially considering the cost of Synology, or Qnap Nas units. I've been tinking around newegg and put this together. I'm wondering if anyone can tell me if it's powerful enough for streaming hd video, music, and photos to multiple devices concurrently (no more than two devices at a time). Also, would like to know if there's anything here that won't work with freenas. and possible gains on read/write speeds to the unit I might see. I currently have high speed cable internet, with speed boost, and a Cisco EA4500 router. I can write to a drive connected to the router at 16 mbs...Hoping this system can do much better? If not maybe I shouldn't build.
Motherboard:
ASUS C60M1-I AMD Fusion APU C-60 (1.0GHz, dual core) AMD Hudson M1 Mini ITX Motherboard/CPU Combo
HD:
WD 3TB Red
Memory:
8gb (4 x 2) Corsair 1333 memory (I know the board says it only excepts 1046, but i'm assuming the memory will work at the slower speed?)...if not I can use it for my main machine.
Power Supply (Sitting in a box at home):
Antec 500w Earthwatts (has 5 sata, but could buy molex to sata adapter eventually?)
USB thumb Drive:
8 gb Sandisk low profile
Case:
Fractal Design Define Mini Black Micro ATX Silent PC Computer Case w/ USB 3.0 support and 2 x 120mm Fractal Design Silent Fans
Motherboard:
HD:
WD 3TB Red
Memory:
USB thumb Drive:
Case:
