I am not very good at finding out how to fix my problems
I am using freenes 11.2
nextcloud 17
and I have errors the 1st one is I am trying to update my nextcloud and I get this
* ## Check for write permissions
The following places can not be written to:
* /usr/local/www/nextcloud/updater/../.htaccess
I can find where this is to fix it
next I get these
There are some warnings regarding your setup.
* PHP does not seem to be setup properly to query system environment variables. The test with getenv("PATH") only returns an empty response. Please check the [installation documentation ↗](https://docs.nextcloud.com/server/17/go.php?to=admin-php-fpm) for PHP configuration notes and the PHP configuration of your server, especially when using php-fpm.
* MySQL is used as database but does not support 4-byte characters. To be able to handle 4-byte characters (like emojis) without issues in filenames or comments for example it is recommended to enable the 4-byte support in MySQL. For further details read [the documentation page about this](https://docs.nextcloud.com/server/17/go.php?to=admin-mysql-utf8mb4).
* Accessing site insecurely via HTTP. You are strongly advised to set up your server to require HTTPS instead, as described in the [security tips ↗](https://docs.nextcloud.com/server/17/go.php?to=admin-security).
the docoumts on these that the link has is for other os freenes is different it has jails and I can figure out how to fix it
then I get this in Nextcloud
Invalid private key for encryption app. Please update your private key password in your personal settings to recover access to your encrypted files.
I change the password but nothing happends and I can find out how to fix it
and the last thing
how do I get webdev to work with windows out side my network nextcloud tells me to use this
yourdomain.com
the nextcloud instruction in nextcloud is using https do I need to setup ssl to make it work out side my network or is there a work around that I can setup in my router or freenes
or how do I set up nextcloud to make it work
please help and thank you
nextcloud 17
next I get these
and the last thing
Best Website Builder Online | Yoursite
Start Your Site & Connect With The World. Create your website and go online now! All plans include custom mailboxes and web hosting.
