Hi
I'm new here because I decided to rebuild my IT environment and also switch from my QNAP NAS to TrueNAS. I thought it out nicely and prepared a few things to make this possible (devices, division, migration, etc.).
Unfortunately, I only watched the evaluation videos regarding TrueNAS and didn't read anything in this forum, so I'm now at a critical point.
I bought various hardware for my new NAS
- a mini PC (Intel Alder Lake-N100, 1TB NVME, 1TB SSD, 16GB DDR4)
- a Yottamaster 5 Bay RAID hard drive enclosure [PS5RU3]
- a Lian Li EX-503 HDD Hot Swap enclosure (I had this one for a few years already)
- both cases should be connected to the USB 3 ports of the PC
- 3x 8TB SATA HDD
- 3x 2TB SATA SSD
- I might want to reuse a few more disks for backup raids
Installation went well (TrueNAS-SCALE-23.10.0.1), as did installing the 8TB HDDs in the Lian Li housing and I was able to create and test my media storage. I then added 2 more HDDs as a second data set, and that worked too.
Now I wanted to connect the 3x 2 TB SSDs in the Yottamaster. But they are only recognized as one disk!
I now know that the problem is known here and also that a USB setup is not recommended. Unfortunately too late.
Now I have to see how I can carry on anyway. For now, I'm willing to take the risks with the USB setup since I can still keep my old NAS as a backup.
Now my questions:
1.) Does anyone have a Yottamaster case and managed to get it to work? With "lsblk" all disks are recognized, but not in the GUI.
2.) Which 5-bay case works reliably so that the disks can be addressed individually?
3.) I didn't plan to do it that way, but I could repurpose my old desktop (i7-3770K@3.50GHz, 32GB RAM, Big Tower) later. I have several SATA controllers in there. But I would have to migrate everything first before that could happen.
- Can I set up the setup now with the mini PC and then later install trueNAS on the desktop and migrate the disks/datasets (including USB to SATA)? Is that possible?
Thank you for any help. And as I said, I understand that USB setups are not recommended, but want to move forward for now.
- 3x 8TB SATA HDD
- 3x 2TB SATA SSD
Now my questions:
