Help with LSI 9308-e possibly bricked
denywinarto
My LSI card suddenly throw this error after i swap its position in the motherboard :
"unable to load avago technologies MPT Bios. MPT bios fault 0Dh encountered at adapter PCI (02h, 00h,00h)
i have followed this guide https://www.servethehome.com/flash-lsi-sas-3008-hba-e-g-ibm-m1215-mode/
but now i'm stuck, Running all commands before this part :
sas3flash.efi -f SAS9300_8i_IT.bin -b mptsas3.rom -b mpt3x64.rom
Always results in "firmware download required blablabla.. regardless whether i put the pin or not
So i ran it and i got this :
Executing operation : Flash firmware image
Firmware version 16.00.01.00
Firmware Image compatible with controller
Valid NVDATA image found
NVDATA Major version 0E.01
Checking for a compatible NVData Image..,
NVDATA Device ID and Chip revision match verified.
NVDATA Subsystem vendor and Subsytem Device ID match verified
Valid bootloader Image verified
Chip is in RESET state, attempting to host boot
ERROR : firmware host boot failed!
denywinarto
Did you try erasing the card again?
I did, it always says firmware download required.
Strange cause i never used it before, i bought the card a year ago from backup, its from china, but ive had other same card from china and its been running flawlessly for almost 2 years.
