I received an e-mail from my FreeNAS box stating that it was starting a scrub and 3 hours later I received another e-mail with "Security Run Output" in the subject and the following information. Does anyone know what these "changes" to my file system might reference? Also, what does "Device da1p1.eli destroyed" mean, etc.?
FreeNAS.local changes in mounted filesystems: 4c4 < /dev/ufs/FreeNASs2a / ufs ro 1 1 --- > /dev/ufs/FreeNASs1a / ufs ro 1 1 8d7 < zpool1/.samba4 /mnt/zpool1/.samba4 zfs rw,nfsv4acls 0 0 FreeNAS.local kernel log messages: > Waiting (max 60 seconds) for system process `vnlru' to stop...done > Waiting (max 60 seconds) for system process `bufdaemon' to stop...done > > Waiting (max 60 seconds) for system process `syncer' to stop...Syncing disks, vnodes remaining...0 0 0 0 done > All buffers synced. > GEOM_ELI: Device da1p1.eli destroyed. > GEOM_ELI: Detached da1p1.eli on last close. > GEOM_ELI: Device da3p1.eli destroyed. > GEOM_ELI: Detached da3p1.eli on last close. > GEOM_ELI: Device da2p1.eli destroyed. > GEOM_ELI: Detached da2p1.eli on last close. > GEOM_ELI: Device da4p1.eli destroyed. > GEOM_ELI: Detached da4p1.eli on last close. > GEOM_ELI: Device da6p1.eli destroyed. > GEOM_ELI: Detached da6p1.eli on last close. > Uptime: 5d19h34m14s > GEOM_ELI: Device da5p1.eli destroyed. > GEOM_ELI: Detached da5p1.eli on last close. > FreeBSD 9.2-RELEASE-p3 #0 rxxxxxx+1xxxxxx: Fri Feb 28 13:38:48 PST 2014
