Grinas
- May 4, 2017
Sorry for the stupid question but im confused as to which drives are actually degraded.
So long story short i just realized today that i have no gotten an email from truenas in about a year so decides to have a look at the storage to make sure everything is ok but I see 2 drives degraded.
I am confused as to which drive so its showing 9 drives in total listed so that means at least one must be no longer show/detect by truenas. Is the only way for me to find out which one is to get serials of all and open server go through them all?
The other drive that is degraded seems to be da2 which is an very old Toshiba drive but when i go look at the drive states i get "DISK TYPE" "UNKNOWN" for da6 so is da6 degraded too?
Mod note: external images removed
Attached is output of all drives
da1
da2
da3
da4
da6
I assume its da2 and another drive thats not showing that are degraded but why is da6 showing as HDD type "unknown"
da1
smartctl -a /dev/da1
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p6 amd64] (local build)
Model Family: Western Digital Red
Device Model: WDC WD30EFRX-68EUZN0
Serial Number: WD-WCC4N0XP648R
LU WWN Device Id: 5 0014ee 2640bcb11
Firmware Version: 82.00A82
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Aug 2 14:16:31 2023 IST
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (40080) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 402) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 3
3 Spin_Up_Time 0x0027 188 180 021 Pre-fail Always - 5575
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 227
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 040 040 000 Old_age Always - 44452
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 227
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 226
193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 5068
194 Temperature_Celsius 0x0022 110 097 000 Old_age Always - 40
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 1
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 35590 -
# 2 Extended offline Completed without error 00% 32877 -
# 3 Extended offline Completed without error 00% 32853 -
# 4 Extended offline Completed without error 00% 32783 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.da2
smartctl -a /dev/da2
Model Family: Toshiba 3.5" DT01ACA... Desktop HDD
Device Model: TOSHIBA DT01ACA300
Serial Number: X3V9SV5GS
LU WWN Device Id: 5 000039 ff4d2885a
Firmware Version: MX6OABB0
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ATA8-ACS T13/1699-D revision 4
Local Time is: Wed Aug 2 14:17:00 2023 IST
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
been run.
data collection: (22652) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
power-saving mode.
recommended polling time: ( 378) minutes.
SCT capabilities: (0x003d) SCT Status supported.
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 139 139 054 Pre-fail Offline - 70
3 Spin_Up_Time 0x0007 150 150 024 Pre-fail Always - 365 (Average 398)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 586
5 Reallocated_Sector_Ct 0x0033 094 094 005 Pre-fail Always - 276
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 124 124 020 Pre-fail Offline - 33
9 Power_On_Hours 0x0012 092 092 000 Old_age Always - 60867
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 398
192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 1332
193 Load_Cycle_Count 0x0012 099 099 000 Old_age Always - 1332
194 Temperature_Celsius 0x0002 133 133 000 Old_age Always - 45 (Min/Max 13/57)
196 Reallocated_Event_Count 0x0032 093 093 000 Old_age Always - 307
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 120
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 153 153 000 Old_age Always - 1101
Read SMART Error Log failed: Input/output error
# 1 Short offline Completed without error 00% 60410 -
# 2 Short offline Completed without error 00% 60398 -
# 3 Short offline Completed without error 00% 60242 -
# 4 Short offline Completed without error 00% 60230 -
# 5 Short offline Completed without error 00% 60026 -
# 6 Short offline Completed without error 00% 60014 -
# 7 Short offline Completed without error 00% 59858 -
# 8 Short offline Completed without error 00% 59846 -
# 9 Short offline Completed without error 00% 59690 -
#10 Short offline Completed without error 00% 59678 -
#11 Short offline Completed without error 00% 59525 -
#12 Short offline Completed without error 00% 59513 -
#13 Short offline Completed without error 00% 59285 -
#14 Short offline Completed without error 00% 59273 -
#15 Short offline Completed without error 00% 59117 -
#16 Short offline Completed without error 00% 59105 -
#17 Short offline Completed without error 00% 58949 -
#18 Short offline Completed without error 00% 58937 -
#19 Short offline Completed without error 00% 58781 -
#20 Short offline Completed without error 00% 58769 -
#21 Short offline Completed without error 00% 58565 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
da3
smartctl -a /dev/da3
Serial Number: WD-WCC4N6SS9F16
LU WWN Device Id: 5 0014ee 20e541427
Local Time is: Wed Aug 2 14:18:32 2023 IST
was never started.
been run.
data collection: (40020) seconds.
command.
power-saving mode.
recommended polling time: ( 401) minutes.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 1
3 Spin_Up_Time 0x0027 186 178 021 Pre-fail Always - 5666
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 257
9 Power_On_Hours 0x0032 028 028 000 Old_age Always - 52888
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 257
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 242
193 Load_Cycle_Count 0x0032 193 193 000 Old_age Always - 22445
194 Temperature_Celsius 0x0022 109 100 000 Old_age Always - 41
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
No Errors Logged
# 1 Short offline Completed without error 00% 52767 -
# 2 Short offline Completed without error 00% 52755 -
# 3 Short offline Completed without error 00% 52599 -
# 4 Short offline Completed without error 00% 52587 -
# 5 Short offline Completed without error 00% 52431 -
# 6 Short offline Completed without error 00% 52419 -
# 7 Short offline Completed without error 00% 52264 -
# 8 Short offline Completed without error 00% 52252 -
# 9 Short offline Completed without error 00% 52048 -
#10 Short offline Completed without error 00% 52036 -
#11 Short offline Completed without error 00% 51880 -
#12 Short offline Completed without error 00% 51868 -
#13 Short offline Completed without error 00% 51712 -
#14 Short offline Completed without error 00% 51700 -
#15 Short offline Completed without error 00% 51548 -
#16 Short offline Completed without error 00% 51536 -
#17 Short offline Completed without error 00% 51308 -
#18 Short offline Completed without error 00% 51296 -
#19 Short offline Completed without error 00% 51140 -
#20 Short offline Completed without error 00% 51128 -
#21 Short offline Completed without error 00% 50972 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
da4
smartctl -a /dev/da4
Model Family: Western Digital Purple
Device Model: WDC WD30PURZ-85GU6Y0
Serial Number: WD-WCC4N7AY14Z9
LU WWN Device Id: 5 0014ee 265d1adc5
Firmware Version: 80.00A80
Local Time is: Wed Aug 2 14:18:58 2023 IST
was never started.
been run.
data collection: (39600) seconds.
command.
power-saving mode.
recommended polling time: ( 398) minutes.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 190 182 021 Pre-fail Always - 5491
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 120
9 Power_On_Hours 0x0032 061 061 000 Old_age Always - 29072
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 120
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 118
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 647
194 Temperature_Celsius 0x0022 106 092 000 Old_age Always - 44
No Errors Logged
# 1 Extended offline Completed without error 00% 20214 -
# 2 Extended offline Completed without error 00% 17496 -
# 3 Extended offline Completed without error 00% 17472 -
# 4 Extended offline Completed without error 00% 17402 -
# 5 Extended offline Aborted by host 90% 17364 -
# 6 Short offline Completed without error 00% 17179 -
# 7 Extended offline Completed without error 00% 17137 -
# 8 Conveyance offline Completed without error 00% 17129 -
# 9 Extended offline Aborted by host 90% 17129 -
#10 Short offline Completed without error 00% 17129 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
da6
smartctl -a /dev/da6
Device Model: WDC WD30PURX-64P6ZY0
Serial Number: WD-WCC4N6VVXV6T
LU WWN Device Id: 0 000000 000000000
Firmware Version: 01.12B.3
User Capacity: 3,001,489,956,864 bytes [3.00 TB]
ATA Version is: ATA8-ACS (minor revision not indicated)
Local Time is: Wed Aug 2 14:19:24 2023 IST
was never started.
Self-test execution status: ( 115) The previous self-test completed having
the read element of the test failed.
data collection: (42300) seconds.
command.
power-saving mode.
recommended polling time: ( 424) minutes.
1 Raw_Read_Error_Rate 0xfc77 200 200 051 Pre-fail Always - 60
3 Spin_Up_Time 0xe455 223 218 021 Pre-fail Offline - 3808
4 Start_Stop_Count 0xe054 100 100 000 Old_age Offline - 105
5 Reallocated_Sector_Ct 0xf455 200 200 140 Pre-fail Offline - 0
7 Seek_Error_Rate 0xe455 200 200 051 Pre-fail Offline - 0
9 Power_On_Hours 0xec74 064 064 000 Old_age Offline - 26987
10 Spin_Retry_Count 0xd675 100 100 051 Pre-fail Offline - 0
11 Calibration_Retry_Count 0xac14 100 100 051 Old_age Offline - 0
12 Power_Cycle_Count 0xfc34 100 100 000 Old_age Offline - 105
184 End-to-End_Error 0xf477 100 100 097 Pre-fail Always - 0
187 Reported_Uncorrect 0xb414 100 100 000 Old_age Offline - 0
188 Command_Timeout 0xb436 100 099 000 Old_age Always - 1
190 Airflow_Temperature_Cel 0xac76 056 042 000 Old_age Always - 44
192 Power-Off_Retract_Count 0xa474 200 200 000 Old_age Offline - 104
193 Load_Cycle_Count 0xa476 200 200 000 Old_age Always - 0
194 Temperature_Celsius 0xc45c 106 092 000 Old_age Offline - 44
195 Hardware_ECC_Recovered 0xdc7e 200 200 000 Old_age Always - 0
196 Reallocated_Event_Count 0xbc74 200 200 000 Old_age Offline - 0
197 Current_Pending_Sector 0xe674 200 200 000 Old_age Offline - 0
198 Offline_Uncorrectable 0xfc7e 100 253 000 Old_age Always - 0
199 UDMA_CRC_Error_Count 0xc456 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0xbc57 200 200 051 Pre-fail Always - 28
No Errors Logged
# 1 Short offline Completed: read failure 30% 26986 4191536
# 2 Extended offline Completed: read failure 10% 18117 4198216
# 3 Extended offline Completed: read failure 90% 15402 4198216
# 4 Extended offline Completed: read failure 90% 15380 4198216
# 5 Extended offline Completed: read failure 90% 15380 4198216
# 6 Extended offline Completed: read failure 90% 15378 4198216
# 7 Extended offline Completed: read failure 90% 15308 4198216
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.I assume its da2 and another drive thats not showing that are degraded but why is da6 showing as HDD type "unknown"
