Hello guys,
today i'm experiencing some troubles configuring my TrueNAS.
I moved from a ReadyNAS to a Truenas yesterday and now i want to make dataset as it was in my old NAS.
All this because i got lots of links in my Desktop from files placed inside the NAS which i usually found in this kind of path "\\nas\SAVE-LCT\SAVE EMANUELE".
The trouble is that if i put "nas" as hostname and build a pool called "SAVE-LCT" i cant copy things inside the pool (since i got unauthorized warning when try to copy something there) and the only way to use the pool is to create a Dataset and then it works.
If i do this i wont be able to use my existent links anymore since the new path will be \\nas\SAVE-LCT\SAVE-LCT\SAVE EMANUELE".
How could i be able to create a path like i need it to be?
Thanks a lot for the support!
