Hi there,
You gotta check the SMART status of your drive ada4.
Do you have scheduled long and short SMART tests on all your drives ?
smartctl -x /dev/ada4 Start here: https://forums.freenas.org/index.php?resources/hard-drive-troubleshooting-guide.17/What should I do ?
BTW: What is your system config ?
Build FreeNAS-9.10.1-U2 (f045a8b) Platform Intel(R) Core(TM) i5-4430 CPU @ 3.00GHz Memory 16003MB System Time Mon Nov 28 22:18:21 EST 2016 Uptime 10:18PM up 30 days, 3:45, 0 users Load Average 0.67, 0.45, 0.41
You can run the following command for instance:
[root@HomeNAS] ~# smartctl -x /dev/ada4 smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Se Device Model: WDC WD4000F9YZ-09N20L0 Firmware Version: 01.01A01 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ATA8-ACS (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Mon Nov 28 22:19:32 2016 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled AAM feature is: Unavailable APM feature is: Disabled Rd look-ahead is: Enabled Write cache is: Enabled ATA Security is: Disabled, frozen [SEC2] Wt Cache Reorder: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (43860) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 474) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x70bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE 1 Raw_Read_Error_Rate POSR-K 200 200 051 - 0 3 Spin_Up_Time POS--K 147 138 021 - 11616 4 Start_Stop_Count -O--CK 100 100 000 - 47 5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0 7 Seek_Error_Rate -OSR-K 200 200 000 - 0 9 Power_On_Hours -O--CK 076 076 000 - 17634 10 Spin_Retry_Count -O--CK 100 253 000 - 0 11 Calibration_Retry_Count -O--CK 100 253 000 - 0 12 Power_Cycle_Count -O--CK 100 100 000 - 47 183 Runtime_Bad_Block -O--CK 100 100 000 - 0 192 Power-Off_Retract_Count -O--CK 200 200 000 - 28 193 Load_Cycle_Count -O--CK 200 200 000 - 18 194 Temperature_Celsius -O---K 101 087 000 - 51 196 Reallocated_Event_Count -O--CK 200 200 000 - 0 197 Current_Pending_Sector -O--CK 200 200 000 - 20 198 Offline_Uncorrectable ----CK 200 200 000 - 20 199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0 200 Multi_Zone_Error_Rate ---R-- 198 198 000 - 848 ||||||_ K auto-keep |||||__ C event count ||||___ R error rate |||____ S speed/performance ||_____ O updated online |______ P prefailure warning General Purpose Log Directory Version 1 SMART Log Directory Version 1 [multi-sector log support] Address Access R/W Size Description 0x00 GPL,SL R/O 1 Log Directory 0x01 SL R/O 1 Summary SMART error log 0x02 SL R/O 5 Comprehensive SMART error log 0x03 GPL R/O 6 Ext. Comprehensive SMART error log 0x04 GPL,SL R/O 8 Device Statistics log 0x06 SL R/O 1 SMART self-test log 0x07 GPL R/O 1 Extended self-test log 0x08 GPL R/O 2 Power Conditions log 0x09 SL R/W 1 Selective self-test log 0x10 GPL R/O 1 SATA NCQ Queued Error log 0x11 GPL R/O 1 SATA Phy Event Counters log 0x24 GPL R/O 1 Current Device Internal Status Data log 0x80-0x9f GPL,SL R/W 16 Host vendor specific log 0xa0-0xa7 GPL,SL VS 16 Device vendor specific log 0xa8-0xb7 GPL,SL VS 1 Device vendor specific log 0xbd GPL,SL VS 1 Device vendor specific log 0xc0 GPL,SL VS 1 Device vendor specific log 0xc1 GPL VS 93 Device vendor specific log 0xe0 GPL,SL R/W 1 SCT Command/Status 0xe1 GPL,SL R/W 1 SCT Data Transfer SMART Extended Comprehensive Error Log Version: 1 (6 sectors) No Errors Logged SMART Extended Self-test Log Version: 1 (1 sectors) Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 17595 - # 2 Short offline Completed without error 00% 17427 - # 3 Short offline Completed without error 00% 17260 - # 4 Short offline Completed without error 00% 17092 - # 5 Extended offline Completed without error 00% 17076 - # 6 Extended offline Completed without error 00% 17028 - # 7 Short offline Completed without error 00% 16924 - # 8 Short offline Completed without error 00% 16900 - # 9 Short offline Completed without error 00% 16733 - #10 Short offline Completed without error 00% 16565 - #11 Extended offline Completed without error 00% 16501 - #12 Short offline Completed without error 00% 16397 - #13 Extended offline Completed without error 00% 16381 - #14 Short offline Completed without error 00% 16229 - #15 Short offline Completed without error 00% 16061 - #16 Short offline Completed without error 00% 15893 - #17 Short offline Completed without error 00% 15726 - #18 Extended offline Completed without error 00% 15710 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. SCT Status Version: 3 SCT Version (vendor specific): 258 (0x0102) SCT Support Level: 1 Device State: Active (0) Current Temperature: 51 Celsius Power Cycle Min/Max Temperature: 17/60 Celsius Lifetime Min/Max Temperature: 15/65 Celsius Under/Over Temperature Limit Count: 0/0 Vendor specific: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 SCT Temperature History Version: 2 Temperature Sampling Period: 1 minute Temperature Logging Interval: 1 minute Min/Max recommended Temperature: 0/60 Celsius Min/Max Temperature Limit: -41/85 Celsius Temperature History Size (Index): 478 (444) Index Estimated Time Temperature Celsius 445 2016-11-28 14:22 51 ******************************** ... ..(476 skipped). .. ******************************** 444 2016-11-28 22:19 51 ******************************** SCT Error Recovery Control: Read: 70 (7.0 seconds) Write: 70 (7.0 seconds) Device Statistics (GP Log 0x04) Page Offset Size Value Flags Description 0x01 ===== = = === == General Statistics (rev 2) == 0x01 0x008 4 47 --- Lifetime Power-On Resets 0x01 0x010 4 17634 --- Power-on Hours 0x01 0x018 6 186735074152 --- Logical Sectors Written 0x01 0x020 6 444009157 --- Number of Write Commands 0x01 0x028 6 28030410186 --- Logical Sectors Read 0x01 0x030 6 147690918 --- Number of Read Commands 0x03 ===== = = === == Rotating Media Statistics (rev 1) == 0x03 0x008 4 17319 --- Spindle Motor Power-on Hours 0x03 0x010 4 17319 --- Head Flying Hours 0x03 0x018 4 47 --- Head Load Events 0x03 0x020 4 200 N-- Number of Reallocated Logical Sectors 0x03 0x028 4 9018 --- Read Recovery Attempts 0x03 0x030 4 0 --- Number of Mechanical Start Failures 0x04 ===== = = === == General Errors Statistics (rev 1) == 0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors 0x04 0x010 4 0 --- Resets Between Cmd Acceptance and Completion 0x05 ===== = = === == Temperature Statistics (rev 1) == 0x05 0x008 1 51 --- Current Temperature 0x05 0x010 1 52 --- Average Short Term Temperature 0x05 0x018 1 52 --- Average Long Term Temperature 0x05 0x020 1 65 --- Highest Temperature 0x05 0x028 1 22 --- Lowest Temperature 0x05 0x030 1 61 --- Highest Average Short Term Temperature 0x05 0x038 1 41 --- Lowest Average Short Term Temperature 0x05 0x040 1 57 --- Highest Average Long Term Temperature 0x05 0x048 1 42 --- Lowest Average Long Term Temperature 0x05 0x050 4 7730 --- Time in Over-Temperature 0x05 0x058 1 60 --- Specified Maximum Operating Temperature 0x05 0x060 4 0 --- Time in Under-Temperature 0x05 0x068 1 0 --- Specified Minimum Operating Temperature 0x06 ===== = = === == Transport Statistics (rev 1) == 0x06 0x008 4 266 --- Number of Hardware Resets 0x06 0x010 4 607 --- Number of ASR Events 0x06 0x018 4 0 --- Number of Interface CRC Errors |||_ C monitored condition met ||__ D supports DSN |___ N normalized value SATA Phy Event Counters (GP Log 0x11) ID Size Value Description 0x0001 2 0 Command failed due to ICRC error 0x0002 2 0 R_ERR response for data FIS 0x0003 2 0 R_ERR response for device-to-host data FIS 0x0004 2 0 R_ERR response for host-to-device data FIS 0x0005 2 0 R_ERR response for non-data FIS 0x0006 2 0 R_ERR response for device-to-host non-data FIS 0x0007 2 0 R_ERR response for host-to-device non-data FIS 0x0008 2 0 Device-to-host non-data FIS retries 0x0009 2 8 Transition from drive PhyRdy to drive PhyNRdy 0x000a 2 9 Device-to-host register FISes sent due to a COMRESET 0x000b 2 0 CRC errors within host-to-device FIS 0x000f 2 0 R_ERR response for host-to-device data FIS, CRC 0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC 0x8000 4 2615088 Vendor specific
Thanks all for the help, I ordered a new case which comes with a lot fans and awesome cooling specs.
I also filled up a ADVANCE RMA request with WD.
However, i have a dumb question:
I assume the correct procedure is :
1) Plug in the new drive
2) Use the "replace" feature in the FreeNAS GUI
3) Remove the culprit
4) SUCCESS
But my question is "hardware oriented": if I plug in the new drive I'm going to obviously use a different cable and connector than the initial one used by the faulty drive.
Once I'm done, can I unplug it, and use the initial cable and connector previously used by the faulty drive for the new drive? Or I shouldn't play around with that after the switch?
Please let the forum know whether they give you a refund, given that the disk was run above its specified maximum temperature for more than 5 days (assuming the count is in minutes).I also filled up a ADVANCE RMA request with WD.
2. Burn-in the drive/s using the ressources available in the forum (=> sticky)
ZFS bases itself on metadata to assign disks to pools, so you can move them around (or even change controller) and the disk will be recognized and used in the correct volume ;)
You are correct. The directions cover the situation when you have no spare drive ports. If you have a spare port, you can use the more robust approach of resilvering with the old drive in place. It's covered in the directions for replacing drives to grow a pool, but someone really should put in a bug/feature request to have the other directions modified too ;)Not sure about this though... unless there's something I don't understand, the documentation is saying to OFFLINE the failing drive before replacing it?
I really thought I needed to let the resilver complete and THEN offline the disk, and then take it out.
https://bugs.freenas.org/issues/15306someone really should put in a bug/feature request to have the other directions modified too ;)
