SOLVED HELP!! Upgraded to 11.2 & can't boot up server
Btw, when you're back on an even keel, it might be a good idea to update your FreeNAS hardware and software details in your signature.
AltecBX
Good catch! Will do.
AltecBX
OK. So I'm back on FreeNAS.
Now I'm on a new Interface. The IP is different. I see no pool. No Plugin. Everything looks new.
What do I do now?
AltecBX
Redcoat
Follow post 35 in the second string that @Seymour Butt gave you to find the old config file on your pool. Then import/upload that config with the button on the System/General page.
AltecBX
That's what I'm trying to do. Not working for me when I go to Shell and go /Data. I try to do a DIR but nothing.
Redcoat
Drop a bit further down the post - you need to go to /var/db/system
AltecBX
Yep I did that. Then what?
I'm doing this from the Shell in the web browser
Redcoat
Then open the directory configs-averylongnumber and find your dated configuration file that you want to reload.
If you have trouble navigating this from the shell, you might want to consider using SSH and Midnight Commander (mc) to get to the path to enter to upload:
AltecBX
When you're in the prompt (root@FreeNAS[/var/db/system]#), what's the next command?
Redcoat
ls to list the contents and find the full directory name of configs-averylargenumber
That is lower case "ls"
AltecBX
Yep, I got that but what is the command?
- I SSH into the server
- I enter my Name & PW
- Then type: cd /var/db/system/
- Now I'm on line root@FreeNAS[/var/db/system]#
- What's s my next command?
Redcoat
the command is "ls":
I just looked in both tghose and my configs are in the first so run the cursor across it to copy it
type cd (space) right-click for
Hit carriage return, then ls
and there are your config files
AltecBX
Redcoat
Well, those folders are dated today. I guess that you did not have your configuration stored on your pool, but still on the boot drive as was the earlier default. Best thing to do now is to treat it as a blessing in disguise, an opportunity to have a freshly configured install...
AltecBX
So I'm I losing all my Plex data?
AltecBX
AltecBX
I think I'm getting somewhere. I download WinSCP and I can see it here.
Getting warmer... What now?
