Hello.
I'm running a TrueNAS-SCALE-23.10.1.3 system.
I have 3 pools:
Two of them are the running on the same SSD which I partitioned in the setup process (boot pool and then the rest for apps).
Then there is the data pool, which is currently a single 4TB external hard drive connected trough USB.
I now have two 12TB internal disks in the system which I want to use instead of the external drive.
Ideally I would like to keep my existing pool, just add the new drives in stripe (it's just for movies and tv shows, want performance and not data protection) and then remove the external drive, so that I don't have to mess around with any re-configuration of permissions. Maybe I'm overthinking this, but I'm a complete newb.
I've been trying to figure out how I can see what data layout the existing pool is, to make sure it's stripe, or if I should just create a new pool and copy things over using this guide.
www.truenas.com
Here is my pool, does this somehow tell me if its stripe configured? Or give me input on how I should be approaching this?
I have 3 pools:
Howto: migrate data from one pool to a bigger pool
There have been a lot of posts recently about how to move data from one pool to another. Usually it's because folks want to upgrade to a much larger pool and the drive-by-drive resilvering process will take too long. I've recently gone through this as well. Here are the steps that I followed...
