Hi there,
I need to install RancherOS in order to run docker containers.
Therefore I followed:
https://forums.freenas.org/index.php?threads/howto-freenas-11-rancheros-docker-and-portainer.54595/
Unfortunately I'm always running into the same problem if I do:
iohyve install RancherOS rancheros.iso
then log in to the console on another shell
'ls' lists the devices afaik, and it displays only: (hd0) (host)
if I then try linux /boot<tab> it does not find anything, if I hit enter to test it, it says:
error: disk 'cd0,msdos1' not found.
what am I doing wrong?
