HELP plex 1.7.40 wont install
oumpa31
I thought the old install was screwed up so i tried to reinstall it and now all i get is:
[EFAULT] Failed to install chart release: Error: INSTALLATION FAILED: Deployment.apps "plex" is invalid: spec.template.spec.containers[0].resources.limits: Required value: Limit must be set for non overcommitable resources.
All i did was put a claim token in and i didn't even set the data locations.
I assume from the message that you are trying to install the plugin version. The plugins are essentially all but dead. Very easy to install in a jail manually, many, many posts about it.
oumpa31
I think i put this in the wrong spot Sorry. The machine is running scale.
