Help needed with cron jobs not running automatically
Update: see solution in 3rd post
I'm on TrueNAS-SCALE-23.10.0.1, but this issue has been with me for a while. I've set up a few cron jobs (in system settings/advanced), and while they run without problems when executed manually (triangle icon), they never run automatically.
One of my jobs runs "heavyscript backup" at 3 am (see attached image). After a manual run, I'm sent an e-mail with the output. It's all good as long as I run it manually, however, nothing happens at 3 am - no email, no backup made. On the other hand, replication tasks run on time and reports are sent, and I also get emails about other outstanding issues, so it's not an issue with the notification system or all cron jobs. Nextcloud cron jobs (configured by the Truecharts app) also run regularly (as far as they're present in journalctl), but my own cron jobs don't. And this isn't something that worked until one point and then broke, this cron job has never run by itself as far as I can tell.
I'd appreciate any advice on how to dig deeper to understand and fix the issue.
I've found some threads in these forums about cron jobs, but none of these seemed to focus on a similar issue.
Tony-1971
Try using
/usr/bin/bash
instead of
bash
Best Regards,
Antonio
Thank you for the suggestion, but this was not the issue. The /etc/cron.d/middlewared file includes /usr/bin in its path so "bash" is just as good as "/usr/bin/bash".
However, I was able to identify the cause. One of my cron jobs had the minute defined as 1/10 instead of */10 and this caused the following error (from journalctl -xe):
Dec 01 22:36:01 MainNAS cron[3313]: (*system*middlewared) RELOAD (/etc/cron.d/middlewared)
Dec 01 22:36:01 MainNAS cron[3313]: Error: bad minute; while reading /etc/cron.d/middlewared
Dec 01 22:36:01 MainNAS cron[3313]: (*system*middlewared) ERROR (Syntax error, this crontab file will be ignored)
The offending cron job:
1/10 * * * * root PATH="/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin:/root/bin" midclt call cronjob.run 1 true > /dev/null 2> /dev/null
I've changed it to */10 and now it runs as expected.
However, while I'm not certain it's correct cron syntax or not, 1/10 is recognised as correct by the UI! It's telling me that 1/10 means every 10 minutes starting from 1. So, even though it was a mistake on my part, the UI didn't complain about it. I'm wondering if it's an oversight.
Now that all jobs are running, I'm having another issue with not being able to hide their output. One job that runs every 10 minutes has both stdout and stderr output hidden (both boxes checked) and I'm still getting an email every 10 minutes. Did I overlook another setting that overrides the ones in the job's configuration?
Patrick M. Hausen
Just add >/dev/null 2>&1 to the end of your command.
Yes, that works, but did I misunderstand the purpose of the "hide output" checkboxes in the UI?
Patrick, would you let me know what you think about the above error with the cron job? Is 1/10 supposed to be OK or not? I'm aware this is very likely a minor issue, especially since a workaround is easy, but the discrepancy between the UI and system running the job might be worth a ticket.
