AlgernonUK
- Feb 9, 2013
Not sure if this should go here, as it's about development, or in the noob forum, cus I'm new.
I am building a NAS from a Mini ITX with an atom 525, and will be making a custom case for it.
Part of the case will be an LCD panel driven by an Arduino, which will show various stats.
So, I started up a shell, and tested a quick python script to output data to the arduino through serial usb.
I'm new to python, but noticed that when trying to run this script, it didnt have the serial library imported.
So I downloaded and extracted the tar. And followed the instructions to install it
python setup.py install
only to be told that /usr/local/lib is a read only file-system
Is what I'm trying to do possible? And if so, how do I go about doing it?
Any pointers greatfully received.
Al.
import serial
mySerial = serial.Serial('/dev/ttyUSB0' , 9600)
mySerial.write("Woot")
mySerial.flushOutputI'm new to python, but noticed that when trying to run this script, it didnt have the serial library imported.
Al.
