[HELP]LSI 9260 8i Crossflash
ssts100
Hi guys, I find a good server that use LSI 9260 connect to a 12 bay back plane.
Can I crossflash it with 9211?
If not, will 9211 8i work with 12 bay back plane?
Thanks for all the help.
Dice
It might help if you provide a bit more detailed information of this "good server".
Dice
I doubt that raid card can be cross flashed to pure HBA since it features BBU.
You should probably ask the seller if the setup accepts +2TB drives and if possible to change the raidcard for a HBA. Or, you could sell the raidcard your self and get a HBA.
The SAS 9260 cannot be flashed to IT mode and cannot use the mrsas driver.
tl;dr: You need a different card
