So my zvol was showing Degraded with bad Checksums on a disk yesterday. I did a scrub, and in the zpool status it showed 62 Read Errors for a drive, and eventually kicked it out of the pool
I did a long SMART test of the disk in question and from what I can tell it seems ok. Can I get a second opinion and ok before I throw it back in and resliver it? Or should I RMA it?
Device Model: ST2000VN000-1H3164
Serial Number: W1H3Z363
LU WWN Device Id: 5 000c50 073f7958a
Firmware Version: SC42
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Rotation Rate: 5900 rpm
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Mon Sep 1 16:50:17 2014 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 117) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 278) minutes.
Conveyance self-test routine
SCT capabilities: (0x10bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 114 099 006 Pre-fail Always - 63304888
3 Spin_Up_Time 0x0003 096 096 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 7
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 072 060 030 Pre-fail Always - 17514138
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 537
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 6
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 4295032833
189 High_Fly_Writes 0x003a 099 099 000 Old_age Always - 1
190 Airflow_Temperature_Cel 0x0022 069 059 045 Old_age Always - 31 (Min/Max 25/33)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 4
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 8
194 Temperature_Celsius 0x0022 031 041 000 Old_age Always - 31 (0 24 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 29
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 536 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
