Maturola
 - Jun 26, 2014
This may be an Pfsense issue and I asked on their forum with no help so far, however just in case is something on Freenas I'll ask here.
Looking for someone running jail (specifically Sabnzb, Sickbread, Couchpotato or Owncloud) and trying to access any of the jail ebconfigurators using Dynamic DNS URL
I setup Dynamic DNS last night, and everything seen to be working great, then I setup port forwarding for a single server (SABnzb), SABnzb is running on the FreeNAS box under a jail with its own IP on port 8086.
I went ahead and try from 'OUTSIDE' my network and I can access the server using <Public IP>:8086 & <dynamic DNS URL>:8086
Everything working as intended so far...
Now, here is the issue I don't seen to understand...
from 'INSIDE' my network, I can access the server using <Public IP>:8086, <Internal IP>8086, <hostname>:8086 however using <dynamic DNS URL>:8086 doesn't work, it try to load for a while and then time out.
This are commonly used FreeNAS jail+Plugins and I know some of you out there are using PFsense as well... have anyone encountered this issue?
Honestly I can VPN in a access all servers configuration, but what's worry me the most is Owncloud, my IP is dynamic as home user and I need to use the Dynamic DNS URL to setup the clients, which mean currently it will be unreachable when I am inside my network,
Anyways, any guidance would be appreciated.
Thanks
mat
Thanks
mat
