Help Error Message
depasseg
FreeNAS Replicant
Yes, the 9300 hba. I think I posted the exact steps and file names around here, but I don't have the time to search right now.
eddie200112
PH10 has been released by Supermicro at the previously listed FTP address.
eddie200112
Do I want to install the IT or IR version?
eddie200112
Would anyone familiar with supermicro boards be willing to dumb these install instructions down for me? Do I set my bootable drive ahead of the freenas boot drive and then install? Where do I get this 9 digit character from?
Thanks!
Flashing IR mode in UEFI mode
1) Please copy all files from UEFI folder to bootable USB disk
2) Run SMC3008R.nsh and following the instruction to enter the last 9 digits/character of the SAS address.
3) If you are having problem to enter the SAS address, please use the command below to set the controller SAS address.
sas3flash.efi -o –sasadd “Controller SAS address”
For example: sas3flash.efi -o –sasadd 50030480070a8b00
4) Reboot the system
depasseg
FreeNAS Replicant
If you are asking about IT vs IR, you should really do a little more reading.
You want IT though. And I've posted much simpler directions in a couple other posts.
Sent from my Nexus 6P using Tapatalk
eddie200112
Even though I see LSI IR something or other when I boot the server?
eddie200112
I couldn't find the directions you say you've posted, sorry if I'm being a dumb best I just have too much data on here already to be willing to risk my normal tinkering.
eddie200112
Ah sweet I found a nice tutorial. But I definitely currently have the IR firmware installed. So if I update to the IT firmware will that screw with my pool or cause me to lose data?
No. IT is like IR, but with the RAID features stripped out. As long as you didn't configure the disks for HW RAID, it'll be fine.
eddie200112
eddie200112
SO I typed in SMC3008T.nsh on that page and ended up with this after 2 minutes.
Now I'm worried I screwed this up...
Hmm, no need to worry yet. Just tell it to flash the firmware image you have on the drive.
eddie200112
So how do I do that. Im not familiar with how to use uefi. I haven't used it before. Do I just type in the name of the rim file I think it was something like 3008it10.rom
eddie200112
Please anyone? I litearally cannot find anymore detailed instructions for this other than the one I found and it doesn't tell me how to do this.
eddie200112
Problem solved. Realized I hadn't actually mounted the flash drive first.
