Hi all,
I'm moving from a Windows Pro for Workstation environment to TrueNas Scale. The machine I'll be using is a Ryzen 3800 (which will go to a 5950) with 128gigs of ram, 2 1tb nvme's and 16 6tb spinning drives connected via a 12g SAS HBA. The 16 drives are in a storage space running REFS and I'm using PrimoCache (read/write cache) on top of the storage space.
I've been mostly happy with it, but am bumping up against some limitations, notably iSCSI.
The machine is used for three main workloads:
I've spent a fair amount of time reading through different approaches to pool design, but I can't say I feel confident about any of my conclusions. My initial thinking was to put them all into one Pool with 4 4 disk VDEVs, but looking through the forum, I'm not sure that's the right approach. Any guidance is appreciated.
Thanks!
- It's the plex server for the house. Part of that is taking recordings from the two tuners I have and transcoding them to H265. That's currently hardware accelerated. We typically have 3 or so concurrent streams
- It's an NVR for our IP security cameras. I'm using Blue Iris + DeepStack for object detection. There are 6 camera streams, either 4k or 1080p. The CPU usage on this is crushing the machine right now, hence the upgraded processor
- It's fileshare for all the PCs on the home network. In particular, I want to put my and my kid's steam library on it, vs adding yet more storage to one of our machines, hence the iSCSI need
Thanks!
