Hello.  I'm new to these forums, but not new to Truenas.  Been using for years, since it was Freenas.  I'm upgrading a server I have running sas, lsi cards.  I have a 2008 lsi hba controller, 8i.
I have questions, was hoping to get advice. I am confused trying to buy upgrade sas controller, I need 2 more cables internal, to fill another bay in that server. Right now I have the 2008 i8 card, it only has 2 cables come out that serves 8 drives in one bay. I added another bay for 8 more drives, but maxed out on cables out of this controller. I need another 2 more of those same cables out, to handle a total of 16 drives, in 2 bays.
I want to upgrade to lsi 9300 controller. But it seems more confusing. the 9300 8i controllers look like they have different connectors, with 4 ports on it (reference images below):
I can see the cables are paired, so it gives 4 ports out, with the cables is 8 ends on a 9300 8i. What confuses me is that my 2008 8i controller has only 2 ports (image below):
So.... Why a 2008 8i says "8i" with only 2 ports, that provide for 8 drives - and the 9300 8i has 4 ports. How many drives does the 9300 handle? Is that a whole different type of backplane that I can not use, because of the SAS III level or something? If that is the case, then I would not be able to use the 9300 card because my existing drive bays wont accept the type of controller, and I would just need to buy another 2008 controller with 4 internal ports instead of 2, to serve my additional 8-drive bay.
Can someone please help with advise? Thank you.
