HDD & SDD temp alert level
sgaar
All,
How do you change the levels at which the system gives a temperature alert for a given HD (HDD or SDD)? I have 2 Sandisk SSDs in my NAS which can operate at much higher temperatures than HDDs but the alert is the same for all of the disks (spinning or not).
The SSDs can safely operate 32ºF to 158ºF (0ºC to 70 ºC) but the system still gives an alert at 45 ºC. Can that be changed?
Bidule0hm
Server Electronics Sorcerer
IIRC @cyberjock made a tuto about changing the temp threshold only for the SSDs ;)
Bidule0hm
Yes, exactly ;)
