HBA Hardware issue LSI-9211-8i
Jmdestroy
Hi all,
I am pretty new to Truenas Scale (I have a raidz2 vdev working on motherboard SATA ports and I was hoping to add more disks with an HBA card in IT MODE) and completely new to HBA.
I just bought a LSI-9211-8i from Ali Express.
I plugged it in my system. The card seems to be recognized but not the disks.
Browsing forums I was able to check my system boot log and everything seems fine for the card but not a single HDD is showing up. (I don't see the HBA card bios at boot, don't know if it's normal or not)
Is there anything else I need to do for the 2 attached disks to show up ? Are there any commands to list the drive attached to the card ? (SAS2IRCU & SAS3IRCU LIST are giving me MPTLib2 Error 1)
Thanks in advance for your help.
admin@truenas[~]$ sudo dmesg | grep mpt
[sudo] password for admin:
[ 0.006175] Device empty
[ 1.750690] mpt3sas version 39.100.00.00 loaded
[ 1.754225] mpt3sas 0000:10:00.0: enabling device (0000 -> 0002)
[ 1.755302] mpt2sas_cm0: 64 BIT PCI BUS DMA ADDRESSING SUPPORTED, total mem (14225532 kB)
[ 1.822940] mpt2sas_cm0: CurrentHostPageSize is 0: Setting default host page size to 4k
[ 1.823722] mpt2sas_cm0: MSI-X vectors supported: 1
[ 1.825283] mpt2sas_cm0: 0 1 1
[ 1.825458] mpt2sas_cm0: High IOPs queues : disabled
[ 1.826889] mpt2sas0-msix0: PCI-MSI-X enabled: IRQ 87
[ 1.828436] mpt2sas_cm0: iomem(0x00000000fce40000), mapped(0x0000000084303e6d), size(65536)
[ 1.829694] mpt2sas_cm0: ioport(0x000000000000f000), size(256)
[ 1.891928] mpt2sas_cm0: CurrentHostPageSize is 0: Setting default host page size to 4k
[ 1.919954] mpt2sas_cm0: scatter gather: sge_in_main_msg(1), sge_per_chain(9), sge_per_io(128), chains_per_io(15)
[ 1.921016] mpt2sas_cm0: request pool(0x000000000596648e) - dma(0x100580000): depth(3492), frame_size(128), pool_size(436 kB)
[ 1.927290] mpt2sas_cm0: sense pool(0x00000000dfd9200f) - dma(0x100600000): depth(3367), element_size(96), pool_size (315 kB)
[ 1.928040] mpt2sas_cm0: reply pool(0x00000000481fe999) - dma(0x100680000): depth(3556), frame_size(128), pool_size(444 kB)
[ 1.928742] mpt2sas_cm0: config page(0x0000000073d28279) - dma(0x161b52000): size(512)
[ 1.929408] mpt2sas_cm0: Allocated physical memory: size(7579 kB)
[ 1.930055] mpt2sas_cm0: Current Controller Queue Depth(3364),Max Controller Queue Depth(3432)
[ 1.930705] mpt2sas_cm0: Scatter Gather Elements per IO(128)
[ 1.976066] mpt2sas_cm0: overriding NVDATA EEDPTagMode setting
[ 1.977218] mpt2sas_cm0: LSISAS2008: FWVersion(20.00.07.00), ChipRevision(0x03), BiosVersion(07.39.02.00)
[ 1.978016] mpt2sas_cm0: Protocol=(Initiator,Target), Capabilities=(TLR,EEDP,Snapshot Buffer,Diag Trace Buffer,Task Set Full,NCQ)
[ 1.981674] mpt2sas_cm0: sending port enable !!
[ 4.550682] mpt2sas_cm0: hba_port entry: 0000000007461ab8, port: 255 is added to hba_port list
[ 4.553144] mpt2sas_cm0: host_add: handle(0x0001), sas_addr(0x5b8ca3a0e5d3ba00), phys(8)
[ 9.676954] mpt2sas_cm0: port enable: SUCCESS
Jmdestroy
Additional info (I can't edit post)
Hardware :
- MSI X470 Gaming Plus
- Ryzen 3 3200G
- HBA card is in pcie 1 slot (x16 configured with gen2 pcie bandwidth in bios)
Jmdestroy
Just forget about I tried again today switching the SAS to SATA cables and I just didn't push them strong enough into the HBA adapter.
SOLVED.
