Not sure whether to start another thread or not. I'm sure someone will tell me if I am wrong ;-)
I replaced my controller card with a 16 port card (SVNXINGTII SAS9300-16i 9300-16i16-Port 12Gb/s SAS-3 SAS/SATA PCIe HBA IT Model ZFS) from Amazon yesterday. I have put ALL of my drives on this new card.
I saw this error on the console earlier today:
I looked up the error from the console and saw that it could be a loose cable or connector, so I moved the connectors around (to see if the error stayed on the same drive), plugged them back in (to reset the other end of the cables) , and rebooted.
Then I noticed this error (it could be that the pool was degraded earlier, but unfortunately I didn't look at the web page to see):
I ran the smart_report.sh script from FreeNAS-scripts-master and got this:
########## SMART status report summary for all SATA drives on server PHONG ##########
|Device |Serial |Temp| Power|Start|Spin |ReAlloc|Current|Offline |Seek |Total |High | Command|Last|
| |Number | | On |Stop |Retry|Sectors|Pending|Uncorrec|Errors|Seeks |Fly | Timeout|Test|
| | | | Hours|Count|Count| |Sectors|Sectors | | |Writes| Count |Age |
|da0 |PNY21442111050102589 |33 | 12766| 218| | | | | N/A| N/A| N/A| N/A| 1|
|da1 |PNY21442111050102587 |33 | 12765| 218| | | | | N/A| N/A| N/A| N/A| 1|
|da2 |WD-WX72A9232NL9 |31 | 3118| 69| 0| 0| 0| 0| N/A| N/A| N/A| N/A| 1|
|da3 |WD-WX42D517A0YV |33 | 13744| 219| 0| 0| 0| 0| N/A| N/A| N/A| N/A| 1|
|da4 |WD-WX32DB08YEHU |33 | 10387| 167| 0| 0| 0| 0| N/A| N/A| N/A| N/A| 1|
|da5 |WD-WX42D614DP0Z |33 | 13981| 214| 0| 0| 0| 0| N/A| N/A| N/A| N/A| 1|
|da6 |WD-WX12D415NYJC |32 | 11052| 152| 0| 0| 0| 0| N/A| N/A| N/A| N/A| 1|
|da7 |WD-WX12D41361E7 |32 | 11042| 152| 0| 0| 0| 0| N/A| N/A| N/A| N/A| 1|
|da8 |WD-WX92DA0LJUKF |31 | 11344| 161| 0| 0| 0| 0| N/A| N/A| N/A| N/A| 1|
|da9 |WD-WX92DA0L9CVT |32 | 11292| 158| 0| 0| 0| 0| N/A| N/A| N/A| N/A| 1|
|da10 |NF9351W1004740S30B |25 | 753| 14| | 0| | | N/A| N/A| N/A| N/A| 1|
|da11 |NHH737W1039820S30B |25 | 852| 16| | 0| | | N/A| N/A| N/A| N/A| 1|
|da12 |NF9351W1005300S30B |34 | 775| 14| | 0| | | N/A| N/A| N/A| N/A| 1|
|da13 |NHH737W1039630S30B |23 | 838| 14| | 0| | | N/A| N/A| N/A| N/A| 1|
|da14 ! |WWY0ACWY |54* | 3996| 50| 0| 0| 0| 0| 0| 395656636| N/A| 8590065666| 1|
########## SATA drive /dev/da0 Serial: XXXXXXXXXXX2589
########## Phison Driven SSDs (PNY CS900 120GB SSD)
1 Raw_Read_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 12766
12 Power_Cycle_Count 0x0012 100 100 000 Old_age Always - 218
168 SATA_Phy_Error_Count 0x0012 100 100 000 Old_age Always - 0
170 Bad_Blk_Ct_Erl/Lat 0x0003 100 100 000 Pre-fail Always - 0/61
173 MaxAvgErase_Ct 0x0012 100 100 000 Old_age Always - 22 (Average 1)
192 Unsafe_Shutdown_Count 0x0012 100 100 000 Old_age Always - 181
194 Temperature_Celsius 0x0023 067 067 000 Pre-fail Always - 33 (Min/Max 33/33)
218 CRC_Error_Count 0x000b 100 100 050 Pre-fail Always - 0
231 SSD_Life_Left 0x0013 100 100 000 Pre-fail Always - 99
241 Lifetime_Writes_GiB 0x0012 100 100 000 Old_age Always - 27
No Errors Logged
Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
Short offline Completed without error 00% 12745 -
########## SATA drive /dev/da1 Serial: XXXXXXXXXXX2587
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 12765
170 Bad_Blk_Ct_Erl/Lat 0x0003 100 100 000 Pre-fail Always - 0/92
173 MaxAvgErase_Ct 0x0012 100 100 000 Old_age Always - 25 (Average 1)
No Errors Logged
########## SATA drive /dev/da2 Serial: XXXXXXXXXXX2NL9
########## WDC WD20EFZX-68AWUN0
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 204 203 021 Pre-fail Always - 2791
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 70
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 096 096 000 Old_age Always - 3118
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 69
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 63
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 16
194 Temperature_Celsius 0x0022 116 097 000 Old_age Always - 31
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
No Errors Logged
Short offline Completed without error 00% 3104 -
########## SATA drive /dev/da3 Serial: XXXXXXXXXXXA0YV
3 Spin_Up_Time 0x0027 198 197 021 Pre-fail Always - 3058
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 224
9 Power_On_Hours 0x0032 082 082 000 Old_age Always - 13744
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 219
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 206
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 50
194 Temperature_Celsius 0x0022 114 098 000 Old_age Always - 33
No Errors Logged
Short offline Completed without error 00% 13723 -
########## SATA drive /dev/da4 Serial: XXXXXXXXXXXYEHU
3 Spin_Up_Time 0x0027 199 197 021 Pre-fail Always - 3016
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 167
9 Power_On_Hours 0x0032 086 086 000 Old_age Always - 10387
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 167
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 161
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 15
194 Temperature_Celsius 0x0022 114 099 000 Old_age Always - 33
No Errors Logged
Short offline Completed without error 00% 10367 -
########## SATA drive /dev/da5 Serial: XXXXXXXXXXXDP0Z
3 Spin_Up_Time 0x0027 198 197 021 Pre-fail Always - 3066
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 215
9 Power_On_Hours 0x0032 081 081 000 Old_age Always - 13981
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 214
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 201
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 48
194 Temperature_Celsius 0x0022 114 100 000 Old_age Always - 33
No Errors Logged
Short offline Completed without error 00% 13960 -
########## SATA drive /dev/da6 Serial: XXXXXXXXXXXNYJC
3 Spin_Up_Time 0x0027 198 197 021 Pre-fail Always - 3100
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 153
9 Power_On_Hours 0x0032 085 085 000 Old_age Always - 11052
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 152
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 149
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 14
194 Temperature_Celsius 0x0022 115 101 000 Old_age Always - 32
No Errors Logged
Short offline Completed without error 00% 11031 -
########## SATA drive /dev/da7 Serial: XXXXXXXXXXX61E7
3 Spin_Up_Time 0x0027 198 197 021 Pre-fail Always - 3075
9 Power_On_Hours 0x0032 085 085 000 Old_age Always - 11042
194 Temperature_Celsius 0x0022 115 100 000 Old_age Always - 32
No Errors Logged
Short offline Completed without error 00% 11021 -
########## SATA drive /dev/da8 Serial: WDXXXXXXXXXXXJUKF
3 Spin_Up_Time 0x0027 197 197 021 Pre-fail Always - 3116
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 162
9 Power_On_Hours 0x0032 085 085 000 Old_age Always - 11344
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 161
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 158
194 Temperature_Celsius 0x0022 116 101 000 Old_age Always - 31
No Errors Logged
Short offline Completed without error 00% 11323 -
########## SATA drive /dev/da9 Serial: XXXXXXXXXXX9CVT
3 Spin_Up_Time 0x0027 198 198 021 Pre-fail Always - 3066
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 159
9 Power_On_Hours 0x0032 085 085 000 Old_age Always - 11292
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 158
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 155
No Errors Logged
Short offline Completed without error 00% 11271 -
########## SATA drive /dev/da10 Serial: XXXXXXXXXXXS30B
########## Lexar SSD NS100 2TB
5 Reallocated_Sector_Ct 0x0013 100 100 010 Pre-fail Always - 0
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 753
12 Power_Cycle_Count 0x0012 100 100 000 Old_age Always - 14
164 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 21475295238
165 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 7
166 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 5
167 Unknown_Attribute 0x0022 100 100 000 Old_age Always - 6
194 Temperature_Celsius 0x0022 026 026 000 Old_age Always - 26 (Min/Max 20/46)
199 UDMA_CRC_Error_Count 0x0012 100 100 000 Old_age Always - 0
241 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 27093
242 Total_LBAs_Read 0x0032 100 100 000 Old_age Always - 83184
No Errors Logged
Short offline Completed without error 00% 731 -
########## SATA drive /dev/da11 Serial: XXXXXXXXXXXS30B
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 852
12 Power_Cycle_Count 0x0012 100 100 000 Old_age Always - 16
164 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 12885295108
165 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 6
166 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 3
167 Unknown_Attribute 0x0022 100 100 000 Old_age Always - 4
194 Temperature_Celsius 0x0022 024 024 000 Old_age Always - 24 (Min/Max 19/38)
241 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 27137
242 Total_LBAs_Read 0x0032 100 100 000 Old_age Always - 171598
No Errors Logged
Short offline Completed without error 00% 830 -
########## SATA drive /dev/da12 Serial: XXXXXXXXXXXS30B
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 775
164 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 17180327941
166 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 4
167 Unknown_Attribute 0x0022 100 100 000 Old_age Always - 5
194 Temperature_Celsius 0x0022 028 028 000 Old_age Always - 28 (Min/Max 20/48)
241 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 27108
242 Total_LBAs_Read 0x0032 100 100 000 Old_age Always - 108371
No Errors Logged
Short offline Completed without error 00% 752 -
########## SATA drive /dev/da13 Serial: XXXXXXXXXXXS30B
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 838
164 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 12885229572
165 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 5
194 Temperature_Celsius 0x0022 024 024 000 Old_age Always - 24 (Min/Max 19/43)
241 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 27123
242 Total_LBAs_Read 0x0032 100 100 000 Old_age Always - 146414
No Errors Logged
Short offline Completed without error 00% 816 -
########## SATA drive /dev/da14 Serial: XXXXXXXXXXXACWY
########## ST10000DM005-3AW101
1 Raw_Read_Error_Rate 0x000f 083 064 044 Pre-fail Always - 197014840
3 Spin_Up_Time 0x0003 088 088 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 73
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 086 060 045 Pre-fail Always - 395656653
9 Power_On_Hours 0x0032 096 096 000 Old_age Always - 3996
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 50
18 Unknown_Attribute 0x000b 100 100 050 Pre-fail Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 8590065666
190 Airflow_Temperature_Cel 0x0022 046 025 000 Old_age Always - 54 (Min/Max 33/64)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 25
193 Load_Cycle_Count 0x0032 094 094 000 Old_age Always - 12181
194 Temperature_Celsius 0x0022 054 075 000 Old_age Always - 54 (0 26 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 2304 (96 214 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 12426814994
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 605359293401
No Errors Logged
Short offline Completed without error 00% 3975 -
I don't see anthing that stands out, but then again, I never see the ketchup in the refrigerator :-/
I'm running a scrub on it now
