Have set up a wrong interface
DDiSoEsT
I entered this, hit apply and im stuck again, no connection to the gui..
i have set the same ip adress on the 10gbit port the server is connected to, on my pc
Patrick M. Hausen
First, you can post real screen shots for the GUI. That phone picture was just a friendly hint for the VGA console ...
Second, I don't have a clue. If you are using the GUI via igb0/DHCP assigning a static address to a different interface should work. But then I have not used 11.1 for years ...
Try configuring all interfaces via console ...
Patrick M. Hausen
P.S. your PC of course needs a different address! Like 192.168.22.28 for the FreeNAS and 192.168.22.27 for the PC. And please do not make up random networks. Stick to 192.168.x.y - x must be the same for PC and FreeNAS but different from 178. y must be different for PC and FreeNAS.
DDiSoEsT
Lol
Configuring the ip of ql1 on console did just work without any crashes!
Lets see if it works on windows too
DDiSoEsT
Ok, i got all up and running. Had to configure some initial setting to make my network card ( HP NC523SFP) working.
Now i still have a big problem. Everytime i connect to the NAS via the 10Gig link, i can see the folders and the capacity i can open folders but every time i do that too often (like opening 5 folders after and after in like 10 seconds) windows explorer kinda crashes or is not responsible. Same if I try to copy data on the NAS through 10Gig, 50% of the time it crashes and 50% it does copy until the end.
Also the transfer speed is only 100-350Mb/s, even though i copy from an m.2 on the client to the 2ssds in raid 0, which both have a potentual of 10Gbits..
Can amy of you help me?
DDiSoEsT
also i can access the ssd raid on the server through the normal 1gig link on my pc and this gives me absolutely no trouble, 112Mb/s.
I assume that its the network cards on both devices but idk..
Tried cooling them with fans so far, no change..
