marshalleq
- Mar 12, 2016
Hi all, I'm just wondering if anyone has tried this? The reason I am back here again looking at truenas scale is simply just because unraid is extremely poor at the basic stuff you get with all other NAS's.  And from time to time I get annoyed with it and want to shift.  If I recall correctly the reason I didnt go to Truenas previously was because the docker interface was really clunky, vm's were quite inflexible and most responses to questions for help came from one individual that was quite unhelpful.  Also I remember it was extremely limiting, where unraid lets you use any docker image, truenas at the time did not - I think it was meant to but it didnt work and the interface was so clunky you'd spend hours going over the same thins to no avail.  Truecharts at the time did not have enough apps and good suggestions were rejected,so that was fairly limiting and I've had further rejections in time gone by - I honestly don't see the point in Trucharts, perhaps someone can enlighten me because, much time has passed and things have undoubtedly moved on since then.
Truenas remains for me probably the most polished NAS when it comes to the basics, file permissions, backups, replication, hardware failures etc. For example unraid recently included ZFS as standard but unfortunately made it worse than when it was only a plug-in. The implementation now makes it so that you have to stop your entire array to replace a failed disk (among other things), which is all due to the licensing being tied to a running array with a number of Licenced discs. They've just announced a new licensing model which is also based on a number of discs so I don't see this problem changing any time soon. And as is often true in life there's no perfect answer for anything but at this point I'm pretty tired with unraid and it's anti NAS abilities so I'm back here again.
There really isn't a reason why Truenas scale shouldn't be able to do everything unraid does and it has been a few years since I've been in so here I am having another look. Of course the core of each product is aimed at a different type of user and unraid serves its base very well. But, in a past life I did a lot of these things in large enterprise orgs, so I know what I'm missing.
To date my opinion is that for the management interface of docker and VM's unraid does a better job than everyone else - and how their App Store works leads the way. But for everything else truenas wins - except perhaps that my impression is proxmox is better as a stand alone hypervisor.
So I was thinking for docker and perhaps some things like reverse proxy a good interim is virtualise existing unraid for docker into TrueNAS, import all my ZFS disks (created in command line so should be pretty standard - I.e no unraid funkiness), perhaps migrate the vm's to TrueNAS native (currently qcow images which I like but I recall TrueNAS was not very flexible in this regard i.e cant over provision) and go from there?
Failing that I guess it's proxmox.
Thoughts?
Thanks.
Marshalleq
Thoughts?
Thanks.
Marshalleq
		%20(1)%20(1)%20(1)%20(1).png)
