RavenNAS
 - Mar 7, 2022
Hello all,
Ive been tinkering with SCALE on an old computer for a while now and I want to step it up in a new build focusing on power efficiency, Ill be following some low power NAS guides but Im just not 100% on best practices for setting up the hardware and Im willing to use more power for better reliability as Im hoping this sustem will be in service a over a decade.
Primary uses for system
- Network storage (mostly long term)
- Jellyfin
- Nextcloud
- expandability for use with VMs (short term tinkering)
What I would like to know is what would be best to say; install truenas on 2 small mirrored SSDs, have another ssd for a fast dataset along with your storage say 6 hhds on a pci card (or on the motherboard if thats fine idk)
Currently i have a
- 1tb ssd partitioned for truenas install and for storage dataset for VMs and cache (I know this isnt ideal and it was a pain to do, I want to get away from it with new system).
- 4x 2tb hhds (for now)
- 32gb ram
- 4port sata pci card (dumb)
Which file system would be recommended? Currently using ZFS. Keep in mind Im looking for power efficiency.
Thank you
- Jellyfin
- Nextcloud
Currently i have a
- 32gb ram
Thank you
