Christian_128
- Jan 13, 2015
After updated freenas from 9.X to 11.1 U6 with the graphic update tool.
I received a message about the hard drive have a problem.
OK, I make my home work and read on the forum tread about disk failure, I found the disk : it was the one where freenas was install.
my question, the file "/usr/local/lib/libtdb.so.1" is use for what and how is possible to correct this alert (problem) ?
I try to found discussion on this file "libtdb.so.1" but no result found on the forum, before I start a new tread.
my setup :
super micro X7DB8,
Build FreeNAS-11.1-U6
Platform Intel(R) Xeon(R) CPU L5420 @ 2.50GHz
Memory 32729MB
if you have a clue, let me know :)
The boot volume state is ONLINE: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
after : zpool status -xv: ================================================== root@Serveur1:/mnt/data1/secur3 # zpool status -xv pool: freenas-boot state: ONLINE status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: http://illumos.org/msg/ZFS-8000-8A scan: scrub repaired 0 in 0 days 00:02:54 with 1 errors on Sun Sep 16 03:47:54 2018 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 ada0p2 ONLINE 0 0 0 errors: Permanent errors have been detected in the following files: freenas-boot/ROOT/11.1-U6@2017-06-28-11:26:28:/usr/local/lib/libtdb.so.1
my setup :
super micro X7DB8,
Memory 32729MB
