Resource icon
Hard Drive Burn-In Testing - Discussion Thread
Chris Moore
I started the burnin on Sept 4 th at 10PM and it's still churning away.
That does sound like it is slightly long. I can't recall exactly how long the last burn-in I did took, but I think it was around six days. I have done as many as 12 drives at a time without impacting other functions on the NAS.
NasKar
I can't tell if it's running the same tests over again. Here is the output
+ Run SMART extended test on drive /dev/da8: Sun Sep  8 01:25:34 EDT 2019
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION ===
Sending command: "Execute SMART Extended self-test routine immediately in off-line mode".
Drive command "Execute SMART Extended self-test routine immediately in off-line mode" successful.
Testing has begun.
Please wait 457 minutes for test to complete.
Test will complete after Sun Sep  8 09:02:34 2019
Use smartctl -X to abort test.
Extended test started, sleeping 27420 seconds until it finishes
SMART self-test complete
# 1  Extended offline    Completed without error       00%        83         -
# 2  Short offline       Completed without error       00%        76         -
# 3  Extended offline    Completed without error       00%        75         -
# 4  Short offline       Completed without error       00%        68         -
# 5  Extended offline    Completed without error       00%         7         -
# 6  Short offline       Completed without error       00%         0         -
Finished SMART extended test on drive /dev/da8: Sun Sep  8 09:04:20 EDT 2019
+ Run badblocks test on drive /dev/da8: Sun Sep  8 09:04:20 EDT 2019
Checking for bad blocks in read-write mode
From block 0 to 976754645
Testing with pattern 0xaa: set_o_direct: Inappropriate ioctl for device
Broadcast Message from root@freenasSuper.local
        (no tty) at 13:02 EDT...
UPS ups on battery
UPS ups on line power
done
Reading and comparing:  59.80% done, 11:24:21 elapsed. (0/0/0 errors)                      done
Testing with pattern 0x55: done
Reading and comparing: odondone
Reading and comparing: done
Testing with pattern 0x 79.60% done, 58:22:37 elapsed. (0/0/0 errors)ors)                      done
79.61% done, 58:22:39 elapsed. (0/0/0 errors)elapsed. (0/0/0 errors)
80.94% done, 58:29:51 elapsed. (0/0/0 errors)
Last time I did a 4 TB drive it took ~ 3 days and 5hrs
Meyers
I see that this drive had two short and two long tests run on it recently. Is it possible you accidentally ran the script more than once for each drive? Check how many badblocks processes are running per drive. I just burned in 8TB drives and it didn't take this long.
NasKar
How do you check how many badblock processes are running? The disk-burning directory only has one log file and one bb file (bad blocks).
The burnin finally stop at 5am today. About 7 days. I'll reboot before running the burnin on the remaining drives.
ps aux | grep badblocks would be one way.
Ruff.Hi
I am looking at this bash script to test some new HDDs coming my way. It runs and creates a log file that I can see when logged into the command shell via putty (logged in as root) ... but I can not see the log files in file explorer (windows). Googling suggests that I need to run file explore as admin ... that didn't help.
I have run this script on a different NAS with none of these problems? Any suggestions?
NasKar
I am looking at this bash script to test some new HDDs coming my way. It runs and creates a log file that I can see when logged into the command shell via putty (logged in as root) ... but I can not see the log files in file explorer (windows). Googling suggests that I need to run file explore is admin ... that didn't help.
It worked great on all the other drives I ran it on. Don't know why it took so long on the 1st one. Make sure you run it in a tmux session.
Ruff.Hi
I added an 's' to the end of my share ... so that I knew it was a share. That made the windows path different from the NAS path. I just deleted the share (the one with the 's') and recreated it. Bingo ... log files are visible in Windows Explorer.
Ruff.Hi
The file in ssh but not in explorer is also a ownership issue. I chown'd them back to me and now I can see them in both situations.
I got 3 x 4TB WD Reds on Thursday. They are working their way through the burn-in script (short test, long test, bad blocks, short test, long test). I have noticed that one of the drives is taking much longer than expected on bad blocks.
Drive 1 ... currently at 20% done on a read / compare with pattern 0x55 (the 2nd pattern) after 24:34 hrs
Drive 2 ... currently at 30% done on a read / compare with pattern 0x55 (the 2nd pattern) after 24:43 hrs
Drive 3 ... currently at 2% done on a read / compare with pattern 0xaa (the 1st pattern) after 20:28 hrs
Drives 1 and 2 are over 3/8 way through and on their way to finish at around the 65hr mark (about normal). Drive 3 is only 1/8 of the way through and is looking to finish at about the 160hr mark.
Edit: I just watched all drives for a minute ... Drive 1 moved on 0.26%, Drive 2 moved 0.26% and Drive 3 moved 0.10%.
How do I test through put?
Ruff.Hi
Turns out I had a bad / fault data cable or seat. I am rerunning the burn-in again. Back in about 80 hrs :(
HolyK
Ninja Turtle
FYI ... Just finished burn-in of three of my new WD "White" 12TB
badblocks took 166 hours per disk (running parallel)
badblocks -sw -b 4096 -c 32768 /dev/daX
I'm commissioning a shiny new NAS for work and left the disks (10 TB WD Reds) being subjected to badblocks over the weekend, when nobody's around to complain about the noise. I guess I could've used a weekend twice as long as normal...
S1RC
I've gone through this process before I built my first array. I've got some new drives to burn in, can this process be run in a jail?
hezohab
Wow, 7 days to complete 1 drive?
I am using the same model of drives.
Would you mind describing which tests your and what settings you used for the test?
Is it smartctl short, long and badblocks?
I know very little, I am just getting started.
Thanks!
HolyK
Ninja Turtle
@hezohab Hi, yes. I ran SMART short test on all. Then LONG test on all. After that i ran badblock with -c 65535 on all 6 disks in parallel (via TMUX) but system got stuck and i got UDMA CRC Error on one of the disks. Not sure if i've just hammered the SAS or the stuck was a just consequence of that error. Anyway i've replaced the SATA cable and started badblocks with -c 32768 and on three disks in parallel. Once finished i did the other three. After that i ran the long SMART again.
smartctl -t short /dev/daX
smartctl -t long /dev/daX
badblocks -sw -b 4096 -c 32768 /dev/daX   //!! Data Destructive test !! Run only on new/empty disks!
yourmate
Having lost all my data it's time to update the 4TB WD Reds with 8TB ones. [Just a note on 8TB WD Reds - while the "normal" ones are running at 49-55 C (in contrast 4TB ~ 32-34 C) the helium ones are running at the same temperature as 4TBs at 32-36 C]
Is this still the "FreeNAS recommended" procedure to burn in disks or is there an updated procedure?
Many thanks
Spearfoot
He of the long foot
Many thanks
Yikes! Sorry to hear about you losing all of your data!
Don't know if there's an official recommended procedure, but I always burn-in new drives, and I've created a resource to help people do that:
yourmate
Thanks a lot!
Unfortunately, I already started hammering them by the time I read your message but I bookmarked your script. There is always a next time :)
Mastakilla
Trying these tests as well now...
A useful command in case you want to see the progress of the smartctl long test:
echo /dev/da[0-7] | tr " " "\n" | xargs -L 1 smartctl -a | grep "progress" -i -A 1
Replace 'da[0-7]' with whatever your disks are...
You can use a similar command to launch the smartctl tests too
Btw:
Is it normal that FreeNAS 11.3U2 Reporting does not see any Disk I/O during the long SMART test?
Edit:
When running badblocks, it does report I/O.
Teeps
Thanks for the tip on the boosted -c option, kicking off a 10TB Toshiba MG06ACA10TE presently.
I'm curious if anyone knows what this message below means:
From block 0 to 2441609215
0.23% done, 1:32 elapsed. (0/0/0 errors)
It only shows up in a few posts elsewhere and it's unclear if there's an issue
