Hacking WD Greens (and Reds) with WDIDLE3.exe
@Linkman
Can you post the output of smartctl -a -q noserial /dev/XXX for the two Reds that were set to 8 seconds out of the box?
Linkman
@Linkman
The 8 second default Reds were older models, disc labels said NASware 2.0 versus the newer one's NASware 3.0, but I will try to grab that for you this weekend and post it.
Linkman
First WD Red with 8 second out-of-the-box idle time out, manufactured date 19 Nov 2013, NASware 2.0...
$ sudo smartctl -a -q noserial /dev/sdc
smartctl 5.41 2011-06-09 r3365 [x86_64-linux-3.2.0-82-generic] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
Device Model: WDC WD30EFRX-68EUZN0
Firmware Version: 80.00A80
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 9
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Fri May 1 22:12:16 2015 EDT
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (39600) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 255) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 100 253 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 100 253 021 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 3
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 0
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 3
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 2
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 5
194 Temperature_Celsius 0x0022 130 113 000 Old_age Always - 20
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 253 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Second WD Red with default 8 sec idle time out, also manufactured 19 Nov 2013, NASware 2.0...
ATA Version is: 9
Local Time is: Fri May 1 22:26:40 2015 EDT
was never started.
been run.
data collection: (38100) seconds.
command.
power-saving mode.
194 Temperature_Celsius 0x0022 130 115 000 Old_age Always - 20
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay
Thanks for the output. Unfortunately there is no tell-tale sign that it was set to 8 seconds (I wasn't really expecting one.. just hoping).
Heck, even the firmware version is exactly the same as the one on my mid-2014 3TB Reds.
Did yours have the problem?
<Hopes you say no so I can go "wtf WD!">
  1 Raw_Read_Error_Rate  0x002f  200  200  051  Pre-fail  Always  -  0
  3 Spin_Up_Time  0x0027  179  177  021  Pre-fail  Always  -  6050
  4 Start_Stop_Count  0x0032  100  100  000  Old_age  Always  -  45
  7 Seek_Error_Rate  0x002e  200  200  000  Old_age  Always  -  0
  9 Power_On_Hours  0x0032  091  091  000  Old_age  Always  -  6798
 12 Power_Cycle_Count  0x0032  100  100  000  Old_age  Always  -  45
192 Power-Off_Retract_Count 0x0032  200  200  000  Old_age  Always  -  21
193 Load_Cycle_Count  0x0032  200  200  000  Old_age  Always  -  52
194 Temperature_Celsius  0x0022  123  114  000  Old_age  Always  -  27
199 UDMA_CRC_Error_Count  0x0032  200  200  000  Old_age  Always  -  0
200 Multi_Zone_Error_Rate  0x0008  200  200  000  Old_age  Offline  -  0
I've always taken these as a "no".
The affected drives seem to be from January 2014 at the latest.
Yay...
WTF WD!
9C1 Newbee
Eff you WD with your overly aggressive valets!
LIGISTX
So, getting close to me buying all my stuff (probably 1.5-2 months now). Does it seem like the latest WD greens in 4 TB capacity can be changed to 300? Or just go with reds? I will be getting 9 of them... really don't want to get 9 green drives that cant be "fixed" lol.
Linkman
Based on my recently purchased 3TB Greens, yes, they can be changed to 300 secs.
LIGISTX
There shouldn't be any difference between the 3 and 4 TB ones right?
Sent from my jailbroke iPhone using Tapatalk
Linkman
My assumption is that there isn't any meaningful difference outside of the capacity.
I purchased my 3TB Greens on 3/25, from NewEgg, so I assume they are recent builds. I would be happy to check their manufactured date if you think that will help. The full model numbers and firmware version is listed in my previous post up-thread with the smartctl output.
Ixian
This is from my 3 month old 5tb Red, NASWare 3.0. I have 6 of them, they are all around this. It doesn't look bad but it's not super low either, I can't tell if it's heading in the wrong direction or not?
  3 Spin_Up_Time            0x0027   198   198   021    Pre-fail  Always       -       9083
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       244
  9 Power_On_Hours          0x0032   097   097   000    Old_age   Always       -       2229
10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       16
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       7
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       2111
194 Temperature_Celsius     0x0022   116   110   000    Old_age   Always       -       36
Based on this I think I'm fine but just checking.
244 start/stop cycles are unusual. In such a short time, I'd definitely double check all "power saving" options are off.
Ixian
Would it help explain, perhaps, if I mentioned I pulled these from a Windows 8.1 server where I was using them in a Storage Spaces configuration? That was the first post-Synology server I built before I came to my senses.
Now I have a FreeNAS 9.3 setup with the X10SL7/E3-1230V3/16GB ECC, 6 5TB reds in a Z2 + 2 5tb reds as a backup mirror pool, 512gb ssd for jails. (I've been doing my homework here) and I moved the drives over from that. I just got done doing a full SMART test on them all, which took a while, and am now just double checking any other settings before I start a few stress test passes and then start moving data on over from my backup Synology box.
Is there a tool in FreeNas I can check power saving settings? Other than the obvious one in the GUI disk management.
statalite
Just in case anyone is wondering, I received a WD Purple WD20PURX and the park head timer was disabled from the factory for this one.
Makes sense, since they're supposed to be tweaked Reds.
mac1144
I do understand that wdidle3 does get the wd-green to act more like the wd-red by adjusting the park head timer.
I am thinking about getting together 8 drives into a Fractal Design R4 case. When I first ready about wdidle3 it seemed pretty awesome (and still does) but my other concern is vibrations that wd-red are apparently optimized to handle -- I say 'apparently' because I not sure how much different these 'optimizations' make in the real-world use (for lets say 10 drives or less in an decent home-use enclosure like fractal design R4).
Wondering if someone who has more experience with NAS than I do (I am noob here and to NAS in general) can shed some light on this aspect. If vibrations are not a huge factor then I would love saving money and going greens :)
LIGISTX
My two cents on vibrations: if you are going with a fractal case, every drive will be sitting on silicon pads anyways, these will absorb a lot of the vibrations. Second, I'm not going to say "WD is full of crap" but I am going to say, how much of a deal could it make? I know plenty of people with normal drives in a case with 0 HDD vibration damping and run their pc's 24/7/365 and have not had issues with failures. But I am also a relative Noob to nas, but I am a pretty big normal PC tech head.
