Hi there. I'm trying to setup a DL380e G8 (12-bay) with H220 HBA for use with FreeNAS. The server was working fine and the fans were low (sub 38% for each) until I patched it with the newest HP firmware. Long story short, fans 4-6 went to 58% and holding, which is causing an issue in my home lab. I found this post which is exactly the issue I am having, discussing that I need to revert it back to an earlier firmware of 13.10.141.00...
https://www.reddit.com/r/homelab/comments/7vhrio/fix_dl380_g8_loud_fans_with_h220_hba/
Unfortunately, I can't get past the 2nd step. Here are the steps mentioned from the OP:
1) sas2flsh -o -e 7 (erases the Bios and ROM on the HP H220).
2) sas2flsh -o -f H220_it.bin -b mpt2sas.ROM (flashes the older HP firmware and Bios ROM).
3) sas2flsh -o -sasadd XXXXXXXXXXXXXXXX (replace the Xs with your actual card's sas address written on the back of the physical card).
Step 1 is fine, but step 2 gives me a "Firmware Download Failed!" error and exits the process (see imgur screenshots below). My first thought is the file for the firmware is H220_IT.FW (not H220_IT.BIN), but there is no .BIN file in the HPE Support site link. The file extension shouldn't be that particular, should it? I've looked for the .BIN file for firmware 13.10.141.00 and don't see it anywhere. I'm in FreeDOS and it doesn't have a net connection, so it shouldn't be trying to pull something down online. I've also messaged the OP from that post a few days ago but nothing yet, so decided to post here as well as on Reddit's /r/homelab
Any suggestions or people who have run into this in the past? I'm about ready to just buy a P420 and be done with this, as I hear that should bring the fans back in line with the 35% give or take fan speed.
Images (from remote console) can be found here: https://imgur.com/a/vhuGLzr
