GUI random connection drop
Chris Dawalt
I installed 9.3 a day or so after release, and a few times I have lost the GUI connection, but I still have access to the drives. I can see them and move data back and forth. But the connection (in the browser) times out.
It boots up fine in the morning, and I have access to the GUI initially. At some point, I try to check out the reporting tab for example, but it won't respond, and a browser refresh just times out. This has only happened maybe 3 times. Attached are a couple of screen shots from the last two times this has happened. Is there something I don't have configured properly? Let me know if there is additional info I need to supply.
UPDATE: I got into the console screen, and I see that the address has changed from http://192.168.2.32 to http://192.168.2.34. So I suppose the question is, why the change? And I can now access the GUI with the new address.
D
dlavigne
Guest
Looks like a DNS issue. Which system is 192.168.2.5 (a client or FreeNAS)?
Chris Dawalt
It is the Client - (my PC).
I checked my router:
IP Address
Host Name
192.168.2.34
freenas
192.168.2.31
BRW008092B659AC
192.168.2.20
Chriss-iPhone
192.168.2.5
CHD-PC
192.168.2.3
SAM-PC
pirateghost
Unintelligible Geek
Stop using DHCP or see if your router supports assigning static DHCP leases
Chris Dawalt
It does support static leases - I will look into that. Thanks!
